Mowing Breaking BX Blade Bolts
/ Breaking BX Blade Bolts #41
They did neck down considerably. If it isn't a manufacturing flaw, it could be the friction washers, typically bolts will not neck down that far with a flaw in it. The bolts necking down shows it did its job within the tolerances it was designed to meet.
I believe some elasticity is needed in the material to over come the transfer shock when hitting something, which is what the two cup washers (Friction washers) are for on my 60", They are designed to slip if you hit something when properly torqued. If they have been over torqued in the past, they tend to flatten out, they will not function as designed and transfer the load to the bolt, resulting in failure.
If you insist on reusing the cupped washers, be sure to clean them up good and spray some WD40 on them and WIPE it off(for proper torque), then torque the blades in increments of 3 until the desired torque is reached. Be sure to install them correctly.
/ Breaking BX Blade Bolts #42
I can't tell from the pics, but it looks as though the hole through the blade is larger than the bolt (hole through the washer). Is the spindle stepped to fit the blade hole and keep it centered or is there some other method of keeping it centered, or did they potentially put the wrong blades on.
Custom hardware ticks me off anyway so I would try using a standard HW store bolt instead of a kubota special large head bolt, chances are there was a big bad batch of those distributed to dealers all over.
/ Breaking BX Blade Bolts #43
The more I think about the more of a headscratcher it is. Im starting to wonder if indeed it was a bad batch of bolts.
Id try finding another bolt that fits, like a class 10.9 allen head bolt and try that for a while.
/ Breaking BX Blade Bolts #44
I wonder if when the blades were sharpened they are enough out of balance to be causing some wobble that is working on the bolt at high rpm.
/ Breaking BX Blade Bolts #45
Here are the facts as presented by the OP. Wife took deck to dealer to have blades sharpened. Soon after this bolts started breaking an so on. I would suspect a low skilled 'mechanic' was given the simple job of removing and sharpening the blades and did so using an impact wrench to do so. When he reinstalled the sharpened blades he might have oiled the bolt threads or sprayed something like WD-40 into the spindle holes, and then used the impact wrench set to whatever '/lbs to slam the blades nice and tight. Wife used mower, blade bolt broke. Then another later. This is clearly a dealer related problem and needs to go back to the place that first touched it and sharpened the blades. By possibly overtorquing with an impact, they could have damaged the spindle holes and no bolt, new or used will fix the problem.
Even if someone used oil or antiseize on the bolt threads, or spindle holes and hand torqued the bolts they would still have overtightened them. Bolts- unless specked to be torqued 'wet' are torqued dry so as to NOT overtighten them.
Take it to your dealer who worked on it and let them fix it until it's right. Unfortunately a lot of shops hire cheap, no nothing summer labor to do 'simple' tasks like sharpening blades- BUT the task is obviously not as simple as some might like to think - it takes skill and presents risk of liability to the shop.
Mention your concerns about injury and that they worked on it last, and never having had a problem until they worked on the blades and see what they say.
Do NOT use the mower until it is proven to work to your satisfaction by the dealer.
/ Breaking BX Blade Bolts #46
There was mention that the blades look bowed in the photo.
If they do in person also, would that be an indication of the overtightening that many suspect?
Paul
/ Breaking BX Blade Bolts #47
May look strange, but that is the normal shape for the blades.
/ Breaking BX Blade Bolts #48
Ok...it may be a longshot buuuut. Did they give you YOUR blades back??? It has been known to happen that blades, chains, etc get mixed up. It would explain why all the bolts keep breaking. Maybe?
/ Breaking BX Blade Bolts #50
Even though you have a Snap on torque wrench check it with another know good Snap on torque wrench to be sure it is accurate.
What are you torquing them too?
I removed the other two bolts and they looked fine. I cleaned out each hole with brake cleaner in case their had been lube installed previously. The part number for the bolt has been updated but I didnt think to ask when. I have used the mower about 2-3 hours but will wait to call it a success because it usually takes awhile. I may pull the deck off after another few hours just to inspect.
72-87 is the spec. Ive been doing 75 but this last time I did 72.
Dont know. I was in Kansas when it went down.
/ Breaking BX Blade Bolts #54
Hi,
I just came across this thread and thought that my 2 cents might help.................
The purpose of the bolt is to apply clamping force between the blade and the spindle which causes the friction that drives the blades...
If the blade is distorted and doesn't have 100% contact between the blade and the spindle the blade will not be driven by the by the total area of the spindle and the blade could slip causing the bolt to over over-torque and break......
Take a straight edge and use a feeler gauge to check if the spindle and the area on the blade that contacts the spindle are flat.......
There should be no lube between the spindle face and the blade because this will allow the blade to slip...
An example is the wheel on your car or tractor..If the bolts are under torqued or there is lube between the hub and wheel, the wheel will want not be driven by the hub but rather by the wheel studs and they will fail.....
I drag race and the best way to have your rear wheel come of is to under torque the rear wheel studs?
Just something to check because it might fix the problem
Good luck,
Bob
/ Breaking BX Blade Bolts #55
Hi,
It has been a while since the last post on this problem......
Any updates or a fix for the problem?????
Thanks,
Bob
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2022 EZ-GO ELITE...
JOHN DEERE LV4115 TRACTOR (A63276)
JOHN DEERE LV4115...
2015 Volvo 85160 4yd. Loader Bucket Attachment (A64553)
2015 Volvo 85160...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
