Brass fitting safe to use with diesel
   / Brass fitting safe to use with diesel #1
Clove
Clayton, ON, Canada
Branson 3510i
Branson 3510i, plastic nipple on the left side fuel tank broke off from the tank. Dunno how it happened...guessing snow/ice chunk might have caught it when I was snow blowing. Anyways, got the tank removed and looking to make a repair. Was thinking I'd drill the hole out, tap it/thread it and use a 5/16" barbed x ¼" MPT brass fitting with some 5 min epoxy to set it. I know the tank has to be impeccably clean for this to work, but when researching to see if a brass fitting would be ok to use, I'm getting very conflicting information...some say no problem at all, others say never use brass. So what gives? I was hoping to run down to the local Home Depot to pick up a fitting tomorrow and get the repair done...now I'm not so sure. Any advice appreciated.
   / Brass fitting safe to use with diesel #3
Nothing wrong with brass. Just don't use it on the high pressure side to the diesel fuel system.
   / Brass fitting safe to use with diesel #4
Diesel fuel : many years ago corrosive to copper. I no longer think this is the case . I have a brass 45* ell and short stub of copper attached to fuel line on my Power Wagon with 4BT Cummins , 145 K miles and still running at this moment .
You be the judge if it’s ok to use on a tractor
   / Brass fitting safe to use with diesel #5
You can read this site: IMHO brass will work with
no problems and its cheaper than SS and no spark
willy
   / Brass fitting safe to use with diesel #6
There's brass fittings on my Ford 3000, been there quite a while, no issue.
10 LUG ALUMINUM RIM (A48992)
10 LUG ALUMINUM...
2022 Intimidator 4x4 UTV (A49251)
2022 Intimidator...
Digmaster DM100 Mini Excavator (A49251)
Digmaster DM100...
2018 John Deere 5075E  4WD Tractor (A49251)
2018 John Deere...
45020 (A48082)
45020 (A48082)
Utility Trailer (A48082)
Utility Trailer...
