Branson fuel filter stuck
/ Branson fuel filter stuck #1
runrabbit
Branson 2800H
I have been trying to get the "collar" loose so I can change the fuel filter on my Branson 2800H. It is stuck solid from the factory. I put some channel locks on it, a real tight fit and can't get them on all the way around. I sprayed it with "Creep" and can't budge it. If I reef on the collar any harder I will bust the whole filter assembly off. Anybody else have this problem? Any ideas? I am trying to avoid taking the assembly off all the way, but maybe I have to??
Thanks for your help.
/ Branson fuel filter stuck #2
Have you tried a strap wrench? Sometimes mine on the Kubota gets stuck and Ill use a strap wrench since it distributes the force evenly and doesnt mar the piece.
Thank you! That's the one wrench I don't have. I need to go to town tomorrow to NAPA and get one.
/ Branson fuel filter stuck #4
if you have room stick a flat head screw driver right through it and turn
/ Branson fuel filter stuck #6
Not sure what exactly the “collar” and “assembly” are, but I have used a cold chisel or punch on the filter base in the past with success. Another great tool I keep around is a chain wrench.
/ Branson fuel filter stuck #7
Might call Buster Jenkins in Plainview, TX. and while you are at it, buy your filter from him.....sorta pays for his time...as a courtesy.
806-293-0337
Yeah, I'm going to get a strap or chain wrench in town. The "collar" is what screws to the fuel filter assembly and holds the cap and fuel filter element. I called it a collar. I found a Branson diagram on line and on that it is called a fuel filter assembly.
/ Branson fuel filter stuck #9
The ring that holds the clear plastic filter housing has notches on it all the way around it.
Take a screw driver and a hammer and LIGHTLY tap on one of the notches to the left and it should come off. Be sure to replace the rubber O ring that sits on top of the plastic housing.
Good luck.
/ Branson fuel filter stuck #10
I had a tough time reaching the filter ring on my fuel filter on my Grasshopper (Kubota diesel) when I was trying to use larger wrenches, so I made a simple spanner wrench from a piece of thin rod. I think it was 1/8" or maybe 3/16", and I bent it into a semi circle matching the ring's diameter, with a small tail at one end for a short handle. I bent the tip of the semi circle inwards providing the nipple or tooth that bites the ring. That made it simple to remove the ring.
/ Branson fuel filter stuck #11
Ford850, your ingenuity was put to great use, making your own compact spanner wrench. Great idea for tight places. A spanner wrench is what I was going to suggest and your creativity went one better. :thumbsup:
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
213077 (A64276)
213077 (A64276)
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2022 EZ-GO ELITE...
Great Plains Ultra Till 3030 (A63688)
Great Plains Ultra...
