Branson fuel filter stuck
   / Branson fuel filter stuck #1
runrabbit
Branson 2800H
I have been trying to get the "collar" loose so I can change the fuel filter on my Branson 2800H. It is stuck solid from the factory. I put some channel locks on it, a real tight fit and can't get them on all the way around. I sprayed it with "Creep" and can't budge it. If I reef on the collar any harder I will bust the whole filter assembly off. Anybody else have this problem? Any ideas? I am trying to avoid taking the assembly off all the way, but maybe I have to??
Thanks for your help.
   / Branson fuel filter stuck #2
Have you tried a strap wrench? Sometimes mine on the Kubota gets stuck and Ill use a strap wrench since it distributes the force evenly and doesnt mar the piece.
Thank you! That's the one wrench I don't have. I need to go to town tomorrow to NAPA and get one.
   / Branson fuel filter stuck #4
if you have room stick a flat head screw driver right through it and turn
   / Branson fuel filter stuck #5
Sometime it takes a 1/8 turn and then you need to pull it down to remove the filter
   / Branson fuel filter stuck #6
Not sure what exactly the “collar” and “assembly” are, but I have used a cold chisel or punch on the filter base in the past with success. Another great tool I keep around is a chain wrench.
   / Branson fuel filter stuck #7
Might call Buster Jenkins in Plainview, TX. and while you are at it, buy your filter from him.....sorta pays for his time...as a courtesy.
806-293-0337
Yeah, I'm going to get a strap or chain wrench in town. The "collar" is what screws to the fuel filter assembly and holds the cap and fuel filter element. I called it a collar. I found a Branson diagram on line and on that it is called a fuel filter assembly.
   / Branson fuel filter stuck #9
The ring that holds the clear plastic filter housing has notches on it all the way around it.
Take a screw driver and a hammer and LIGHTLY tap on one of the notches to the left and it should come off. Be sure to replace the rubber O ring that sits on top of the plastic housing.
Good luck.
   / Branson fuel filter stuck #10
I had a tough time reaching the filter ring on my fuel filter on my Grasshopper (Kubota diesel) when I was trying to use larger wrenches, so I made a simple spanner wrench from a piece of thin rod. I think it was 1/8" or maybe 3/16", and I bent it into a semi circle matching the ring's diameter, with a small tail at one end for a short handle. I bent the tip of the semi circle inwards providing the nipple or tooth that bites the ring. That made it simple to remove the ring.
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A55218)
2022 MAXXD BD14...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
