Branson diverter
/ Branson diverter #1
dinoedwards
kubota
2021 Branson 2400H with push button on loader stick diverter valve.
Leaking at fitting.
Are these WR Long or factory from Branson?
Looks like crush washers like brake lines? Or O rings are bad.
/ Branson diverter #2
Have you tried tighten the fittings a bit more? Often it helps with sealing washers.
If not, you can either get copper washers or dowty washers.
EDIT: I would try to clean everything as good as possible and then try to identify the leak more accurately.
/ Branson diverter
They tell me it's a BZ00723B
/ Branson diverter
Looks like 2 different sizes. Did tighten but still leaks slightly, where does ones get these washers?
/ Branson diverter #5
Just google "dowty washers" or "bonded washers". Probably Amazon has tons of those.
Threads looks like 1/2" BSPP to me which would mean a 1/2" washer but you may want to take one of the washers out and measure.
/ Branson diverter
These I assume?
/ Branson diverter
Just ordered these. Hope they work.
New/Unused 20ft X 20ft Steel Carport (A65583)
New/Unused 20ft X...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
48in Farm Jack (A65583)
48in Farm Jack...
(2) Pride of the Farm Waterers (A66408)
(2) Pride of the...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
