Branson BL10 FEL quick coupling 0-ring size
   / Branson BL10 FEL quick coupling 0-ring size #1
skysentinel
Bloomington, Indiana
Branson 3510, Ford 900, Ford 8N
I have looked everywhere, but can't seem to locate any reference to the size of the rubber o-rings that are inside the quick couplings on the Branson BL10 front-end loader. I think there might be a replacement kit that contains the o-ring and a flat teflon backup ring, but I'm not even positive about that. It would be helpful if I just knew what type and size of quick connector Branson uses. Leakage around these connections has been an ongoing problem for years. I suspect the replacement o-rings I'm using are not exactly the right size. I know there are metric and standard sizes, too. What I'm using right now is a standard size ring (7/8" O.D. x 11/16" I.D. x 3/32" Dia.) Any helpful information you can provide will be greatly appreciated.
   / Branson BL10 FEL quick coupling 0-ring size #2
HF sells the assortment boxes of o-rings in US and metric for a reasonable price. (cheaper on sale)
I always just match them up as close as possible from my boxes.
Sometimes I find I need one not in the box but they have saved me lots of trips looking for them.
Stimw, thanks for replying. I have a box of o-rings I was using from, that were sold for use in AC systems (purchased at AutoZone). They were problematic (tendency to slow leak at the slightest provocation). Then I went to Menard's and bought more O-rings off the shelf and tried them (probably sold for plumbing applications). They were just as problematic. Today I went to a local company that sells replacement hydraulic hoses and fittings. I was looking for a metric O-ring that I found in an online catalog, that was just a few hundredths of an inch thicker than the ones I was using, thinking that maybe I was actually using the wrong size. What they told me was, the O-rings I had been using were likely, a "70 durometer" (rubber hardness), and what I actually needed was a "90 durometer." As far as the rubber compound type, the best that I have come up with is that, for high pressure petroleum-based hydraulic oil environments, Buna-N Nitrile rubber is recommended. Now, all I have to find out is the correct O-ring size.
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A50854)
VERMEER VACTRON...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
