Branson 7845 blowing smoke
   / Branson 7845 blowing smoke #11
You can see if the preheater is working, the light is on a temperature related timer,
it looks at coolant temperature and turns the heater circuit on.
It does not monitor the heater, that is located in the intake manifold and has a relay that sends power to the heater.
If you monitor the voltage and carefully feel the intake manifold close to the heater you will be able to feel if it's working.
   / Branson 7845 blowing smoke #12
Your tractor is most likely pre tier 4.
   / Branson 7845 blowing smoke #13
Fresh fuel and injector cleaner would be my next step.
   / Branson 7845 blowing smoke #14
You may want to check your air filters and air intake.
   / Branson 7845 blowing smoke #15
Definitely check your air filter. Not enough air and it will choke. Just remove the filter and let it run for a bit and if that doesn’t improve things then it’s not the filter. Next May want check the fuel filter and fuel separator. After that maybe try to adjust the fuel regulation into the injection pump. Too much fuel can cause black smoke.
International 133 6 Row Cultivator (A50514)
International 133...
2011 New Holland B95B Cab MFWD Loader Backhoe (A51039)
2011 New Holland...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A50854)
KONE CRANES...
