Branson 7845 blowing smoke
   / Branson 7845 blowing smoke #11
You can see if the preheater is working, the light is on a temperature related timer,
it looks at coolant temperature and turns the heater circuit on.
It does not monitor the heater, that is located in the intake manifold and has a relay that sends power to the heater.
If you monitor the voltage and carefully feel the intake manifold close to the heater you will be able to feel if it's working.
   / Branson 7845 blowing smoke #12
Your tractor is most likely pre tier 4.
   / Branson 7845 blowing smoke #13
Fresh fuel and injector cleaner would be my next step.
   / Branson 7845 blowing smoke #14
You may want to check your air filters and air intake.
   / Branson 7845 blowing smoke #15
Definitely check your air filter. Not enough air and it will choke. Just remove the filter and let it run for a bit and if that doesn’t improve things then it’s not the filter. Next May want check the fuel filter and fuel separator. After that maybe try to adjust the fuel regulation into the injection pump. Too much fuel can cause black smoke.
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
