Branson 6530 hydraulic problem.
   / Branson 6530 hydraulic problem. #11
Steve
Have you checked & rechecked the pressure(supply), return & PBY hose connections on your newly installed control valve??? I'll bet some hoses are attached to control valve at incorrect locations.
I appreciate the help. I also apologize for my lack of knowledge with hydraulics. I know how painful it is to watch/listen to people try to do things when they obviously are in over their head.
The thing I adjusted is on the FEL valve itself. A very tall nut, a set nut and a threaded stud with an Allen key. I turned it 2 turns ccw and it corrected the earlier problem.
Like a lot of troubleshooting, fixing one problem just gets you to the next. Now everything works but the bucket tilt function is screwy. A little history. Tractor worked before replacing valve, but it leaked in a few spots Including the valve. I had one of the lift cylinders rebuilt and both of the tilt cylinders Rebuilt. Replaced the valve as earlier discussed. I tried to move some hay yesterday but couldn’t. New problem.
The up/down function seems to work correctly. The tilt function is screwy. With the tractor running and not running the FEL will stay where I set it. I can park it overnight and it’s right where I left it. I’ve checked for leaks everywhere. None. When I attempted to lift a bale the tilt couldn’t hold the weight. tilt also couldn’t roll up with the weight of the bale. Tilt works fine without a load on it.
I have the hay spear installed. I lifted the spear and I hung from it. I’m 200 lbs and I couldn’t move it. Both tilt cylinders rebuilt in last 90 days Due to visible leaks.
when I installed the new valve I had to move fittings and caps from old one to the new one. Everything seemed correct.
Getting this tractor to someone willing to work on it is a pain in the butt. Dealers are few in my area. Any suggestions are much appreciated.
   / Branson 6530 hydraulic problem. #13
Steve, you have some guys helping you that will be hard to find at a local shop. You stated you wanted to learn hydraulics and this is you chance. The key will be performing the tasks asked of you and report back the results.
I would limit use of the tractor while we figure things out or more problems could pop up. Adjusting the relief without a pressure gauge is not a good idea. At some point it will need to be reset to the proper pressure and a gauge will be needed.
If you could post a picture of the current valve and the hoses that connect to the valve, that would help. Pictures of any markings on the valve will help as well. We need to confirm routing and proper set up first.
   / Branson 6530 hydraulic problem. #14
You don't need a dealer, you need someone who knows tractors. In too many cases these days, dealer mechanics don't know much more than you do about your tractor. Owning a handful of tools doesn't make one a mechanic.
Your tractor worked properly before you swapped valves? You changed it mainly because of leaks? Does the valve have six lines or seven?
   / Branson 6530 hydraulic problem. #15
That's the relief valve. You turned the pressure down. Since you're dead heading all the time, the lower relief pressure means the pump is doing less work.
While that's slightly better, it did not correct the actual problem. It's still plumbed wrong and that is likely causing your other issues with the loader. I agree with the suggestion to not use it until this is fixed. If it were mine that would be more than a suggestion.
It's likely that you have connected the tank hose to the PB port on the valve, and the PB port to the tank. Being able to operate the 3pt only when operating the loader valve would indicate that as the valve sends flow out the tank port when it's operated. If you lift anything significant with the 3pt with it plumbed like this there is a good chance that your new loader valve will be damaged. The tank port is not made to handle much pressure.
Hydraulic valves have cast in markings next to each port. Can you read the ones for the ports that do not go to the loader? Or better, get pics and post them? Then we can figure out which hose should be attached to which port.
Good evening. I parked the tractor as suggested. I was baling hay all weekend so I couldn’t reply earlier. I’m using my other tractors, but the Branson is my hay mover. The tractor has six lines. I’m attaching 2 photos. My finger is pointing to the only difference between the old valve and the new valve. On the old valve this port had a plug. I bought a plug to plug off the port I’m pointing to. I’m not sure of the difference. I greatly appreciate your help and advice.
   / Branson 6530 hydraulic problem. #17
The one you are pointing to looks like a Power Beyond sleeve. Can you remove the sleeve and use the plug that was in your old valve for that port?
I think this is the source of the dead heading. With the sleeve installed it is redirecting the flow through fluid from tank to this port and the sleeve is capped stopping flow. When you use the valve, fluid now can flow through the work ports back to the tank port.
Somewhere else there must be priority valve that feeds the rest of the tractor and the loader valve would only have a power port and a tank port.
I can do that. I’ll plug it with the old plug tomorrow. I’ll report the results.
   / Branson 6530 hydraulic problem. #19
I think you need to revisit the two lines to and from the loader valve, where they come from and where they go. I agree that your finger is showing what is most likely a power beyond sleeve.
Just my humble opinion here, but if I were you I would endeavor to keep it and put your current return hose onto it. Then add a third line for a case return. You mentioned the original valve was plagued with leaks? Lack of that third line will eventually cause this valve to have similar problems sooner or later. That's why I asked if the valve had six or seven lines. I suspected it was six.
   / Branson 6530 hydraulic problem. #20
Harry, If you look at his pictures you can see the lines marked on the tractor side. It only has power and tank lines. The 6530 had two different versions for the hydraulic system. It could be that one of them needed power beyond on the loader valve but his does not. Once the sleeve is removed then fluid should be able to flow to the tank port. The loader will be the last valve in this circuit.
Steve, Once this is corrected you will need to adjust the relief valve to get the loader capacity back to where it belongs. You need to get a pressure gauge to do this correctly. Pressure should be somewhere close to 2400psi. Something like this will work.
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
BOX BLADE (A58216)
BOX BLADE (A58216)
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
49205 (A55788)
49205 (A55788)
2020 CATERPILLAR 299D3 SKID STEER (A52709)
2020 CATERPILLAR...
