Branson 3820i
/ Branson 3820i #1
kedwards
Branson 3820
Okay, question........My dumbass put too much oil in my tractor, it's a Branson 3820i. It now has some oil in #2 cylinder. I pulled out the glow plugs to see this. Question is can I turn over the engine safely with out the glow plugs out? Or what is a better way to get the oil out?
Thanks,
Kenny
/ Branson 3820i #2
Thanks,
Kenny
Yes, just make sure all are out (no compression, so it can't start). Best if you can cut off the fuel supply somehow.
Also, since the glow plugs are out and no compression, it would be better if you can rotate the crankshaft manually (should turn easily if you can find a place to put a wrench) and put a towel over top the engine.
/ Branson 3820i #3
Maybe try engaging and turning the pto drive with the tranny in nuetral, it will be slow but will keep you from jamming anything as the oil oozes out:thumbsup:
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2004 John Deere 4720 (A60462)
2004 John Deere...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
