Branson 3520r power loss
   / Branson 3520r power loss #11
Can I use an aftermarket fuel pump 12v should be universal if I'm correct
Just check to confirm that the replacement lift pump has similar flow rate and pressure. I believe the pressure is the biggest difference on models.
New pump, ran fine until warmed up, 1st gear low 2000 rpms full throttle
follow up , after replaced pump , still no power- finally got a chance to troubleshoot it, all pics was flow rate for 15seconds 1st pic is before filter , 2nd pic is going through filter and third is with no filter in it, problem I believe problem is filter, order new one same as original online be here Tuesday hope it fixes it, got 14 acres to mow.
   / Branson 3520r power loss #14
Some of those housing had an inlet screen built into them. You may have some garbage in the inlet of the housing.
   / Branson 3520r power loss #15
I removed my OEM filter assembly on my 3520 - same as your picture- because the hose fitting was leaking and after examination I discovered that the hose fittings were only glued into the housing. So I replaced it with a clear inline auto type. Additionally, the OEM fuel pump has tight tolerances and my pump stopped due to a tiny spec of debris- so I installed the same clear inline auto filter before the pump and haven’t had a problem since.
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
Caterpillar 906M (A53317)
Caterpillar 906M...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
