Branson 3520 fuel water separator
   / Branson 3520 fuel water separator #1
danpalka243
2002 Branson 3520
My fuel water separator was leaking. Changed it out, and tractor won’t start, like it’s getting no diesel. Is there a procedure after changing this to get fuel going? Pic of the old one changed out
   / Branson 3520 fuel water separator #2
There is definitely a procedure. Your manual is your best bet, as there are numerous possibilities on how the fuel system is bled on your particular machine.
Generally, the water separator / filter can be either left loose (so air can escape) with the fuel petcock open until fuel begins spilling out. Some separators will have a bleeder valve or bolt that can be loosened to accomplish the same thing.
If air has been moved past the separator, the procedure may involve opening a bleeder knob or bolt further downstream, and either turning the key on to the start position with the engine not running (electric lift pumps), or cranking the engine on mechanical lift pump systems.
If you have to crank the engine with a bleeder, be sure to limit the cranking time and allow a significant cooling period between attempts.
Finally, some systems self bleed without bleeder screws. My ZD Mowers get the key left on (not running) for a minute or two to bleed air from the system.
2020 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A53426)
2020 KENWORTH T680...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
