Branson 3510i suddenly stops.
   / Branson 3510i suddenly stops. #1
Brucester
Prospect, OR
Branson 3510i
I have a 3510i. Bought it new almost 11 yrs ago. It's been my self employment ever since. This is the third time it's stopped on me. Very frustrating the first time.. So now I know to open the hood and remove the left engine cover and wiggle this plug. Well now it's not even making connection. I have replaced the factory fuel pump with an electric one.. so if the culprit wire makes a connection, I hear it. Well.. Without have the wiring schematic.. I'm guessing this large white wire is the problem. I don't know how to remove the metal plug\spade from the main plug so I can solder it and hope it fixes the intermittent issue.
   / Branson 3510i suddenly stops. #2
I'm not sure how those spades clip into the plastic connector. Generally if you have good eyes and good light and clean up the connector you can find a tab that is down inside the connector that is attached to the metal wire end connector. Technically they make special tools to depress the "hidden" tab and the wire slides right out. But without that tool, you can sometimes use a paper clip to release the tab. I know that isn't much help, you probably know all of that already.
You could do a temporary fix to make sure that your white wire is the issue. Jump a wire around the connector. If that works, you can mess with the connector or just bypass it for that one wire.
   / Branson 3510i suddenly stops. #3
If that does not solve your issue, you might clarify the problem and you will get suggestions on possible other things to look at. If it stops suddenly, I'd suspect the fuel shutoff is not allowing fuel into the pump. If it stops more slowly, as if you are running low and almost out of fuel, it could be the fuel lift pump....and so forth.
Hey there.. I was living in Sacramento and came up to Dave's tractor and bought a new auger with the downforce kit. I haven't been real happy with it.. It pushes so hard it wears out the soft metal cutting teeth adfter a dozen holes. I need a real nice ROCK BIT for it.
So.. back to the main subject.. I went to an auto repair shop this morning and showed them the problem. He pulled both sides of the white wire and put a bullet connector on it. A 5 minute fix. Thanx for the reply "Dave". Speaking of Branson.. I was passing through Grants PAss today and saw that someone is selling Branson's there.
IMG_20180410_182856776[1].jpg Make an Appointment..? Wow..I wonder if I can order parts through them..? I did buy mine from diggerz almost 11 yrs ago. 2700+ hrs on it..
Problem is fixed.. and speaking of fuel. My fuel gauge has been way off for a couple of years. Is the sensor easy to replace on it..? Which tank is it hiding in..?
Thanx..
   / Branson 3510i suddenly stops. #6
View attachment 548269 Make an Appointment..? Wow..I wonder if I can order parts through them..? I did buy mine from diggerz almost 11 yrs ago. 2700+ hrs on it..
Maybe we need to give you less down pressure. :)
We generally carry the carbide tips for the Pengo augers. In tough abrasive stuff they do last longer, but they can chip or break. Or go with a real deal rock bit, but expect to pay a hefty price for such a bit.
   / Branson 3510i suddenly stops. #7
Thanx..
So, what was the problem - the white wire? If so I'd wrap the entire connector with some landscape fabric or hydraulic hose connector material and then cable tie on either side to keep dust/dirt out - AFTER cleaning the entire connector with 'Letra cleaner or similar and blowing out all the crap that's already in it with compressed air.
The fuel sender is hiding in the tank with the wires on top, most likely?!:thumbsup:
Perhaps. I'd like to put a pressure gauge on it and then adjust it accordingly. I'd rather invest into the best rock bit I can. Something built to last. $500..?
Yep.. a bullet connector was installed to keep them together. Then it was heat shrink wrapped and sealed.
It's a permanent fix to a temporary solution.
IMG_20180412_152753251[1].jpg\
   / Branson 3510i suddenly stops. #10
I was just giving you a bit of a hard time about reducing pressure. Because if you want less pressure, you can give it less or apply the pressure more slowly with the spool valve. Drive it down into the soil more slowly.
I'm far from an expert on soil types, but I know they vary widely. Some clay, some loam, some sandy and abrasive, some gravelly, some with big rocks in tight soil, some with big rocks in loose soil....and on and on. On an auger, there are variations in the thickness of the main tube, the thickness of the flighting and the type of tip. If the auger is holding up well to commercial use, but it is just the tips wearing quickly, I'd try some hardened or carbide tips. Some soil types are just rough on auger tips, but it is worth the effort to try to find what works best in your area considering the cost of tip replacement and the time needed to do it. A real deal rock bit will start north of $1000 and may have replaceable bullet teeth like on a trencher chain. Generally they are hexagonal shank and require a good bit of down pressure.
I bet there are some guys on this forum that know a ton more about commercial or heady duty auger work than I do. We do mostly farm type augers and light construction. In any event, you must charge for the bit wear and tear on every hole you dig. Just like a guy doing trenching. Folks don't normally ask you to dig a 12" deep trench in loam. They want a 3' deep trench in rocks!
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
Massimo MB100 Mini Bike (A50121)
Massimo MB100 Mini...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
2016 Caterpillar 349FL Hydraulic Excavator (A50322)
2016 Caterpillar...
John Deere 6175M (A50120)
John Deere 6175M...
