Branson 3510i -Lots of power but moves slowly
   / Branson 3510i -Lots of power but moves slowly #1
josesg
Tractor moves very slow, the engine has lots of power, but it just does not go fast.
Could it be the clutch? Has 86 hours.
jose:confused:
   / Branson 3510i -Lots of power but moves slowly #2
Yes. There should be about 1" of freeplay in the pedal. I bet you have no freeplay. Adjust it and see what you have. Hopefully the clutch is still ok.
   / Branson 3510i -Lots of power but moves slowly #3
Could be the clutch, but have you tried any of the other 11 higher gears? JUST KIDDING :) (assuming you have 12 speeds) We really need some more information. Are all of the other gears including reverse causing the tractor to move at the same speed? If you put it in the highest of ranges (at the lowest gear) does the tractor move or will it just sit there and slip (engine turning and tractor not going anywhere (with burning brakes smell)) will it not spin the tires if you bite into a load with the bucket, or will the tires bite and keep spinning? Let us know, thanks.
Tractor moves very slow in all gears forward and backwards.
Tires don't speed when accelerating.
Had independent mechanic check it out and he believes the clutch is burned out.
Will be taking it to the dealership tomorrow to have it checked out.
Thanks
Jose
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
Frontier AP13D Pallet Forks (A50120)
Frontier AP13D...
1996 Lincoln Town Car Signature Sedan (A50324)
1996 Lincoln Town...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
