Branson 3510 Motor Issue
/ Branson 3510 Motor Issue #21
a lot of white corrosion sounds like it is useing and burning oil,
Took the 3 injectors to Superior Diesel in North Charleston, they took them apart, cleaned and tested them. $127.76 for the work. Apparently they needed it. More later.
OK, a quick update. Got the cylinder head off, there are no cracks. There was a tiny bit of rust on one spot of Cyl. #3 so obviously the gasket was failing, letting some coolant in. Between that and a bad injector, no wonder I was getting some hammering and white smoke..
Now, while the motor is loose, I've found that there is some slop at the connector rod on cyl. #1 so I'll be replacing that bearing. One question, I should be able to get that done without further engine teardown (like removing the piston), correct? It's a pain to reach it from under the tractor with the fwd driveshaft in the way but I can work around that, I'm pretty sure.
/ Branson 3510 Motor Issue #24
Since you are this far along, another hour or two and you can replace all the rings and all of the rod bearings. Might as well. I'd pull the driveshaft out of the way. That will freshen up everything.
/ Branson 3510 Motor Issue #25
Dave is correct. I would check all the pistons and rings. I would at least inspect that one piston and rings. You can check and plastigage the mains one-by-one, if you want. What kind of slop do you have at the rod journal; side to side or excess clearance? Have you plastigaged the bearing?
[Edit: I bought the engine manual to the 3T series
(mod's 2810,3510,3520,4020,4320, and 4520) from my dealer for $54, I think. The head torque sequence is worth that but the photos are such pooooor quality the sequence is not distinguishable. I got the sequence faxed to me through the dealer].
The slop on the rod journal is just excessive clearance.. no side-to-side. I'm going to be ordering an entire set of bearings and rings. I've got a quote of $240.27 for the parts drop-shipping to zip 29412.
I'll be checking the journal for any damage this weekend, and I've never used Plastigauge but it seems simple. (for others who need explanation, this is a great video tutorial - Engine Tech Using Plasti-gauge.mov - YouTube ) I'll do that when I'm installing the new bearings.
Zork - you're correct - the photos in the manual are crap! Barely readable.
OK, I need some help. I don't have the chassis manual, and I'm trying to get the front driveshaft out of the way. Got the front coupling off, not sure on how to disconnect the back end from the gearbox. I drained all the gear oil, turns out I probably didn't need to.. here's a photo of where I am.
Is the shaft supposed to come out of that collar, or behind it? If anybody has a diagram with an explanation, that would be awesome. If it's too dang involved, I might just work around the dang thing to get to the rods.
Thanks in advance,
Bobby
/ Branson 3510 Motor Issue #28
Here is what I have.
  • print 1.pdf
  • print 11.pdf
  • print 12.pdf
/ Branson 3510 Motor Issue #29
Thanks in advance,
Bobby
I ought to just slide out of the coupler once it is disconnected from the front axle.
Got the driveshaft out of the way - thanks for the diagrams, it was just being sticky. Pulled all three pistons. As suspected, the rear connecting rod bearing had spun and was wearing. The other two look fine.
There's some galling on the connecting rod, I need to inspect the crankshaft journal carefully, but it looks ok. Should I replace the connecting rod, or can it be cleaned up or polished and re-used?
/ Branson 3510 Motor Issue #31
I would replace that rod. That bearing appears to have the locating notches missing (due to spin?) and it appears from the photo the bearing is so worn it looks like it incorporates a thrust surface (which according to the Branson electronic diagram I observed the rod bearing should be straight across).
Anyway, the rod journal may be out of round now and the cost to replace it is minimal since it is already out of the engine and in your hand. You may have an additional problem, however. That bearing may have been oil starved and I would check all bearings down stream (rear main?). The lubrication system must be thoroughly checked in order to pinpoint the cause of failure, which may be a blocked oil passage, an improperly installed bearing upstream or its present position, an oil pump malfunction, etc.
/ Branson 3510 Motor Issue #32
The first post on this thread mentioned that the tractor had been significantly overheated. That probably contributed to the failure. Make sure you pull the radiator and get it cleaned.
/ Branson 3510 Motor Issue #33
Any updates?
I'm waiting on some parts to come in. I've gotten everything but 2 rod bearings and those are on back-order from Branson. If any of you guys have them in stock I'll order them from you right away.
Or, if you're aware of another place to source the bearings let me know..
Finally got all of my parts in, thanks to Steen Equipment in Ravenel, SC. Flex-hone gets here tomorrow, then I'll spend the weekend re-assembling everything. Wish me luck.
Success! Spent the weekend putting everything back together and fired her off yesterday. Idled for around an hour with no problems, plan on changing the oil and filter, then running another 10 hours. At that time, I'll re-check the torque on all head bolts, valve clearances, and will also pull the inspection plate on the oil pan and have a look at everything in there just to be sure.
Just to re-cap everything including costs:
Injector cleaning / testing $127.76
3 sets of rod bearings @ $11.42 ea.
3 ring sets @ 57.25 ea.
1 rod assembly @ $107.19 ea.
Head Gasket 1 @ $85.00 (I think)
Bore honer (Flex-hone) $50
So - around $575 - Plus oil / lubricants
/ Branson 3510 Motor Issue #37
Whooohoooo!!!!
Congratulations to you and thanks to all who contributed to Wadmalaw's success.
Now, if that job was done properly you just saved yourself somewhere around $6500. Don't forget to celebrate and take your loved ones out for a little snack somewhere.
/ Branson 3510 Motor Issue #38
OK, you are hired. When can you start? :D
Yes - thanks to all of you guys that contributed advice. I did yell out a big whoohooo when that sucker started up!
Not so fast... after work I changed oil and filter, cranked up, idling with no problem. Took the tracter out for a short run, got up to 2000 rpm and loud tapping noise returned, stayed there when back to idle. Suffice to say I'm pissed. So, I'll open it back up and see if something I replaced might have failed.. stay tuned.
