Brand new Kioti rx7320 Dead in the water
   / Brand new Kioti rx7320 Dead in the water #41
Now that you have figured out what killed your battery, make sure you properly charge up the battery to full charge with the proper charger. I added a 2 pin flat plug from the battery and extended it out to the front of the footboard where it meets the cab, and that gives me a quik and easy way to connect my battery tender to it to keep it fully charged while it sits in the garage.
   / Brand new Kioti rx7320 Dead in the water #42
Hay ironman1952 you don't get any coffee or donuts for the
next 6 months for that mistake:ROFLMAO:
willy
   / Brand new Kioti rx7320 Dead in the water #43
willy
OP gets credit for coming back and admitting a mistake.
I Hope that new Kioti makes him smile every time he gets to use it.
Congrats on the New Kioti,
Now, if we could just get some closure with a Fully functioning CUT for Flyinghigh's Dad.
   / Brand new Kioti rx7320 Dead in the water #44
I think I left my interior light on and I know I left my camera monitor on. That's all it takes. Sorry if you took me as being rude but after your reply, I rest my case. I would have told you the same thing to your face given the opportunity.
   / Brand new Kioti rx7320 Dead in the water #45
I admit i went off the deep end here
Well the OP did go over-the-top right from the beginning…🥴
Just understand that a completely drained battery will have a compromised life span. It would be a good idea to hook up a 2 or 3 amp battery maintainer 24/7. My OEM battery is still going after 10 years, likely due to doing this.
Thanks to the OP for letting us know what the issue was!!
   / Brand new Kioti rx7320 Dead in the water #46
Yes, you NEED to place that battery on a real battery charger to top it off. Dont rely on alternator to top off a truly dead battery.
glad you got it sorted out. I left the cab light on my dodge work truck once….dead twin batteries the next day. Pissed me off to no end. At least my ford truck has a timer that shuts off all lights after 30 minutes of truck not running. Not the dodge.
   / Brand new Kioti rx7320 Dead in the water #47
Does that actually do anything? I've sometimes felt that the relay drew at least as much as the light. Maybe things have changed but I had one truck that the relay would shut the light off, then it would come back on x number of minutes later. Then it would shut off, turn back on, shut back off... all night long.
   / Brand new Kioti rx7320 Dead in the water #48
Well you will all laugh at this (Maybe :))
I cant remember who posted about an interior Cab light left on. Well I decided to try and jump with my truck. After I connected the cables and got inside the tractor i noticed the overhead light on. I dont remember turning it on but I am sure I did. And since I only run it during daylight i never noticed it as it is not a very bright light.
Well long story short i left the truck run for about 1minute and the tractor fired right up.
I guess I have been shafted so many times in life i am skidish. I admit i went off the deep end here :)
On a separate note It interesting how ever since the internet has been around it has turned ordinarliy polite people into rude ones. I am older and have worked on all kinds of machinery over the years not always been a fun experience. Working on equipment in sub freezing temps while it is snowing is not my cup of tea.
Anyway thanks to all for the replies even the not so kind ones :)
I hope to have the same long term experience of all those that have had great luck with their Kioti tractor and their dealer.
Take care and be safe :)
You’re welcome.
   / Brand new Kioti rx7320 Dead in the water #49
well, i left a door open on the truck once overnight when i was working on a fuel filter issue. i did not know i left it open. next morning i saw it and was pissed at myself. figured id have dead batteries. nope, cranked up full power.
   / Brand new Kioti rx7320 Dead in the water #50
Something stupid was done so I threw in the coffee & donuts
was suppose to be funny:unsure:
We all make mistakes but it sure is nice when you correct them
without an added expense
willy
Reel Mower (A55851)
Reel Mower (A55851)
2007 International 4300 Dump Truck (A51692)
2007 International...
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A56138)
2003 VOLVO VNL...
Ratchet Straps (A55852)
Ratchet Straps...
