Brakes Locking up on Kioti.
/ Brakes Locking up on Kioti. #1
AtlanticAcres
2007 Kioti DK 45c
I've a 2007 kioti DK 45. Released the parking brake and brakes lock up after pressing brake pedal. If I tape the brake pedal, brakes release. Pedal travels a lot before engaging brakes.
Thoughts?
/ Brakes Locking up on Kioti. #2
Have you checked if all the return springs on the either the linkage or pedals are in place and not damaged or missing? I would start there.
If not that, my theory is that the brake discs are wore out and the cam system that presses the discs inside the axle housing is getting very close to go over center.
Thank you for the reply. I'll check using your suggestions.
/ Brakes Locking up on Kioti. #4
Any signs of a problem before this or did it just suddenly start locking up the brakes? Turning brakes or one single brake pedal? Could be worn out or possibly just adjusting might help.
/ Brakes Locking up on Kioti. #5
Thoughts?
Any thoughts? Just one. Adjust the brakes so you have proper pedal travel and see what that improves.
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
2014 BMW 5 SERIES SEDAN (A59905)
2014 BMW 5 SERIES...
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
