Brakes Locking up on Kioti.
/ Brakes Locking up on Kioti. #1
AtlanticAcres
2007 Kioti DK 45c
I've a 2007 kioti DK 45. Released the parking brake and brakes lock up after pressing brake pedal. If I tape the brake pedal, brakes release. Pedal travels a lot before engaging brakes.
Thoughts?
/ Brakes Locking up on Kioti. #2
Have you checked if all the return springs on the either the linkage or pedals are in place and not damaged or missing? I would start there.
If not that, my theory is that the brake discs are wore out and the cam system that presses the discs inside the axle housing is getting very close to go over center.
Thank you for the reply. I'll check using your suggestions.
/ Brakes Locking up on Kioti. #4
Any signs of a problem before this or did it just suddenly start locking up the brakes? Turning brakes or one single brake pedal? Could be worn out or possibly just adjusting might help.
/ Brakes Locking up on Kioti. #5
Thoughts?
Any thoughts? Just one. Adjust the brakes so you have proper pedal travel and see what that improves.
JOHN DEERE 844K-III WHEEL LOADER (A65053)
JOHN DEERE...
(APPROX. 20) WOOD VEGETABLE BINS (A64276)
(APPROX. 20) WOOD...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
POTATO BUCKETS (A64276)
POTATO BUCKETS...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
