Brakes explained???
   / Brakes explained??? #1
BILLMAN
MARYLAND
KUBOTA 7500 HSD
Can you guys explain how the brakes work on my B7500. This is my first tractor. I am very familiar w/ automotive brakes but, I sure don't see anything that looks familiar to me. Wet discs? Share the gospel w/ me. Is it OK to mention a B7500 or will TresCrowes get upset?
   / Brakes explained??? #2
<font color=blue>Is it OK to mention a B7500 or will TresCrowes get upset? </font color=blue>
I read on another post where he recommended a fellow take a look at the B7500. I'm not sure he was sincere or feeling well/w3tcompact/icons/wink.gif
The brakes are contained in the rear axle case and each consists of two brake discs and a friction plate between the discs splined with the differential gear shaft. When the brakes are applied a cam plate is forced against the discs and braking is by friction force between the discs and cam plate. All this stuff is emersed in transmission oil and should last a very long time if you don't forget to disengage them to often when running the tractor. I'm not sure if the BX has brakes/w3tcompact/icons/wink.gif
Al
   / Brakes explained??? #3
<font color=blue>I'm not sure if the BX has brakes</font color=blue>
I thought you just put your feet down and dragged your heels. /w3tcompact/icons/wink.gif
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
TOOL BOX (A50854)
TOOL BOX (A50854)
1043 (A50459)
1043 (A50459)
