Brake pedal stuck 5225
/ Brake pedal stuck 5225 #1
VA Rebel
Bronze Member
Ole Virginny
JD4100, JD2555, JD2155, JD5225, JD7720 Combine
Hey everyone, I last drove my 5225 cab mid february (it worked fine) and sometime over the last few months the brake pedal froze. I keep this tractor at a different farm and haven't started messing with it yet. Does anyone have any clue what may have happened? Trying to figure out what I should take with me to fix it. Thanks in advance.
/ Brake pedal stuck 5225 #2
Likely the issue is in the brake valve, and not the pedals. Stored outside, or inside?
If stuck, maybe a real hard push will break it free.
Look at jdparts.com and see how the brake pedals are attached to the brake valve, and your answer may be forthcoming.
Good luck with it..
Likely the issue is in the brake valve, and not the pedals. Stored outside, or inside? If stuck, maybe a real hard push will break it free. Look at jdparts.com and see how the brake pedals are attached to the brake valve, and your answer may be forthcoming. Good luck with it..
All it took was a huge push. Thanks beenthere. I feel a little stupid, maybe a little wimpy but glad it was so easy to fix.
