Brake pedal lock ever fail?
   / Brake pedal lock ever fail? #1
Rebeldad1
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
Living on the side of a mountain I often find myself stopping on a grade requiring using the pedal lock.
Always feels like it positively locks and never had a problem.
It does make you think though if you are working around it. Has the HST so I cant leave it in gear but shut off there is always resistance keeping it from free-wheeling.
Have any of you ever had a issue with yours?
   / Brake pedal lock ever fail? #3
Been using mine every day for over 3 years never had a problem. 25 years with the last tractor.
For ease of use I made this mod no bending over which is not convenient for something used dozens of times a day.
   / Brake pedal lock ever fail? #4
Tractors and hills make me nervous to, so when on a bank I always set FEL down fully on ground, plus I also have a pto winch, I always set that down but thats only good to stop rolling backwards which is very important, and then if I'm not climbing right back on I also set the brakes. So between FEL, brakes and pto winch my tractor is staying put while running, then if I shut the tractor off in gear that makes 4 things holding.
   / Brake pedal lock ever fail? #5
You'll never be sorry for being care full Oldpath05 . One other thing I do is turn the steering wheel so if it does roll it will come up against the nearest tree. If I have some thing I wish to do on the down hill side of the tractor I'll stick a rock in front of the wheel.
   / Brake pedal lock ever fail? #6
Yes I forgot to mention that, I do the same thing, good point......
   / Brake pedal lock ever fail? #7
My 2011 Bobcat CT235 began releasing its parking brake from the vibration of idling to warm up this winter. I adjusted the linkage and it still released. I've adjusted it one more time and it seems to have ceased. I would assure to pay close attention to the brake lock adjustment procedure.
2018 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2018 Chevrolet...
SOFTBALL & BASEBALL HITTING & CATCHING GEAR (A58374)
SOFTBALL &...
2025 AGT MH12RX Mini-Excavator with Pilot Controls & Dozer Blade (New/Unused) (A59225)
2025 AGT MH12RX...
Mini-Excavator Heavy Duty Grapple Attachment (New/Unused) (A59225)
Mini-Excavator...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
