Brake pedal link - B7800
/ Brake pedal link - B7800 #1
twodogs
Pittsburgh, PA
Kubota B7800
The yellow link that holds the brake pedals together just popped off of my tractor. I have kept them linked for as long as I have owned the tractor, so I am surprised that this happened.
I looked on Messick's site to see if there was a retainer of some type to hold it on the peg that it was attached to, but I couldn't see anything there.
Anybody else deal with this? Do you have a solution?
Thanks!
/ Brake pedal link - B7800 #2
If I remember correctly from the B7000 I had, they simply put the link in, then a washer and spot weld the washer to the pivot pin.
Considering the parts catalog showing an entire assembly, I imagine this will be the case for your model as well.
/ Brake pedal link - B7800 #3
Just looked at mine, like a welded pin like the other fellow said. I would remove the rubber pad and put a hole and attach with a bolt and nilock nut. Put rubber pad back on
  • Good Post
Reactions: JWR
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
100 Gal Fuel tank/tool box combo (A65643)
100 Gal Fuel...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A64553)
2014 Tennant ATLV...
1999 Volvo Day Cab Truck, VIN # 4VA7BBRF8XN767346 (A65563)
1999 Volvo Day Cab...
