Brake Light!?
/ Brake Light!? #1
Anonymous Poster
Epic Contributor
I read a post a few weeks ago about someone driving around with the parking brake on. I thought this was odd..seemed had to do right...wrong. Count me in! Darn, I've done this 4 time already, luckily I've caught it relativly quick each time. Good news is I've found my solution... I looked under the tractor tonight..I think I can mount a switch and add a parking brake light to my dash real easy. I'm sure this is much cheaper than the alternative!
/ Brake Light!? #2
Let us know how you mounted the brake light switch. I had a problem with the parking brake in the beginning, but have made an effort to check it before I start moving. and I put a 2X4 in the storrage unit where I keep the tractor that I drive over and then don't set the brake.
I don't seem to have a problem when I set the brake in the open, guess I'm awake then.
/ Brake Light!?
Well...I just finished installing my brake light switch. It works great. I used a piecce of 1" angle iron, drill a 1/2 inch hole for the switch, and two small holes opposite for mounting the brackect to the machine. I used a momentary on normally open bat toggle switch. I drilled a small hole in the end of the switch, mounted the bracket to the tractor, then the sw to the bracket. To actuate the switch I used a spring, put one end through the end of the switch ( hence the small hole I drilled) and put the other end on the brake arm; on the opposite side of the pedal return spring. Kubota nicely made the pin extra long with a hole in allready in place! I put a 1/2" 12v red light in the dash just below the throttle,and picked up the 12V from the ignition (key on-power on,key off power off) side of the headlights...this way the light will NOT stay on when the key is off. I'll try to get some pics to post...dont have a digital cam but my web cam works ok. Total cost...less than $20.00....total savings of not killing my tranny...thousands...Not having to tell my wife I killed my new tractor...priceless!
Ps.....total time ~4hrs start to finish.
/ Brake Light!? #4
Sounds GREAT – I’ll be anxious to see your pics and may try installing one on my Kubota also. One trick I’ve tried so I don’t forget the break is to engage it fully so I notice the extra drag from the parking break immediately rather that half an hour later.
/ Brake Light!? #5
Try engaging just one wheel brake, you should know real quick if the E brake is engaged.
/ Brake Light!?
OK here's some pics..this is a view looking foward...the brake is off. Note switch and spring.
/ Brake Light!?
Now here's a pic with the brake on...again note spring and switch.
/ Brake Light!?
Here's the light on my dash
/ Brake Light!?
And last here's the light "on"..as you can see it's nice and bright.
PS. Can't only set one brake on the bx.
/ Brake Light!? #11
Nice job! Were did you get the switch? Is it spring loaded in the off position? Wire a flasher in the circuit and have it blink to catch you eye. I will be making one myself before i need brakes.
/ Brake Light!?
I got the switch at a local electronics store. Yes, it is a momentary switch, it will return to off on its own. The blink circuit is a good idea....but the bulb is nice and bright, it's hard to miss. That's also why I put it next to the throttle, so when I hop back on and look down It will catch my eye. I'm happy to report that it works well, haven't driven with the brake engaged since I did the mod!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Vicsec 30in. Grading Bucket Mini Excavator Attachment (A61572)
Vicsec 30in...
2015 John Deere 8345R (A64119)
2015 John Deere...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
