Price Check BRAKE ISSUE
/ BRAKE ISSUE #1
MISSION JOE
MISSION B.C
2010 JINMA 404 FORD LGT 125
I OWN A 2010 JINMA 404. WHEN I STEP ON THE BRAKE AN EXCLAMATION MARK LIGHTS UP ON THE DASH. BRAKES SEEM TO BE WORKING FINE. ANY ADVICE WOULD BE GREAT. THANX , JOE...
/ BRAKE ISSUE #2
First thing with the brake light on, check your brake fluid! Also how firm is the brake pedal?
/ BRAKE ISSUE
THE PEDDLE FEELS PRETTY GOOD. WHERE IS THE BRAKE FLUID RES. LOCATED?
/ BRAKE ISSUE
MANUAL STATES THEY"R SEALED DISC BRAKES, (IN CHINGLISH) NOT FAMILIAR WITH THIS .
/ BRAKE ISSUE #5
No brake fluid, they are mechanical.
Chris
/ BRAKE ISSUE #6
I appoligze. I'm not sure if your tractor has hydraulic brakes or mechanical
/ BRAKE ISSUE
THANX FOR THE INPUT. MAYBE LITE IS SO YOU DONT DRIVE WITH BRAKES LOCKED ON , WITH OUT KNOWING IT ... I 'V E-MAILED A COUPLE OF DEALERS FROM THIS SITE . HOPING THEY"LL KNOW FOR SURE... THANX AGAIN , JOE...
/ BRAKE ISSUE #9
I know there's a starter interlock switch underneath the left floorboard. That's why you have to push the clutch pedal to start the engine. Look beneath the right floorboard for a similar switch on the brake linkage. That's likely what turns on the brake indicator in your instrument cluster. My guess is that it's a "hey stupid" light intended to warn owners not to start moving with the brake pedals still locked in the park position.
/ BRAKE ISSUE
THANX TO ALL WHO REPLIED. I MAY NOT HAVE NOTICE THE LIGHT BEFORE THIS. IT IS HARD TO SEE IN THE SUN LIGHT , AND USUALLY WHEN IM BRAKING I HAVE MY EYES ON THE TRAIL , NOT ON THE DASH. HAVE ONLY PUT ABOUT TEN HOURS ON THIS MACHINE SINCE PURCHASE. JUST SORTING IT ALL OUT STILL ! THANX AGAIN , JOE...
/ BRAKE ISSUE #12
Again - look under the right floorboard. The switch that energizes that light may be marginally positioned. It's typically just a one bolt attachment, and is not unusual to discover it's in need of a little fine tuning.
//greg//
New/Unused Wolverine Quick Attach Tree Spade (A65583)
New/Unused...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2022 EZ-GO ELITE...
JOHN DEERE 7420 TRACTOR (A64278)
JOHN DEERE 7420...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
