Price Check BRAKE ISSUE
/ BRAKE ISSUE #1
MISSION JOE
MISSION B.C
2010 JINMA 404 FORD LGT 125
I OWN A 2010 JINMA 404. WHEN I STEP ON THE BRAKE AN EXCLAMATION MARK LIGHTS UP ON THE DASH. BRAKES SEEM TO BE WORKING FINE. ANY ADVICE WOULD BE GREAT. THANX , JOE...
/ BRAKE ISSUE #2
First thing with the brake light on, check your brake fluid! Also how firm is the brake pedal?
/ BRAKE ISSUE
THE PEDDLE FEELS PRETTY GOOD. WHERE IS THE BRAKE FLUID RES. LOCATED?
/ BRAKE ISSUE
MANUAL STATES THEY"R SEALED DISC BRAKES, (IN CHINGLISH) NOT FAMILIAR WITH THIS .
/ BRAKE ISSUE #5
No brake fluid, they are mechanical.
Chris
/ BRAKE ISSUE #6
I appoligze. I'm not sure if your tractor has hydraulic brakes or mechanical
/ BRAKE ISSUE
THANX FOR THE INPUT. MAYBE LITE IS SO YOU DONT DRIVE WITH BRAKES LOCKED ON , WITH OUT KNOWING IT ... I 'V E-MAILED A COUPLE OF DEALERS FROM THIS SITE . HOPING THEY"LL KNOW FOR SURE... THANX AGAIN , JOE...
/ BRAKE ISSUE #9
I know there's a starter interlock switch underneath the left floorboard. That's why you have to push the clutch pedal to start the engine. Look beneath the right floorboard for a similar switch on the brake linkage. That's likely what turns on the brake indicator in your instrument cluster. My guess is that it's a "hey stupid" light intended to warn owners not to start moving with the brake pedals still locked in the park position.
/ BRAKE ISSUE
THANX TO ALL WHO REPLIED. I MAY NOT HAVE NOTICE THE LIGHT BEFORE THIS. IT IS HARD TO SEE IN THE SUN LIGHT , AND USUALLY WHEN IM BRAKING I HAVE MY EYES ON THE TRAIL , NOT ON THE DASH. HAVE ONLY PUT ABOUT TEN HOURS ON THIS MACHINE SINCE PURCHASE. JUST SORTING IT ALL OUT STILL ! THANX AGAIN , JOE...
/ BRAKE ISSUE #12
Again - look under the right floorboard. The switch that energizes that light may be marginally positioned. It's typically just a one bolt attachment, and is not unusual to discover it's in need of a little fine tuning.
//greg//
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
Generac 4000XL Generator (A65579)
Generac 4000XL...
ATS Power ATS-RT12R Mini Excavator (A66408)
ATS Power...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
2006 Mack CV713 Granite Truck, VIN # 1M2AG11C06M033754 (A65579)
2006 Mack CV713...
