Price Check BRAKE ISSUE
/ BRAKE ISSUE #1
MISSION JOE
MISSION B.C
2010 JINMA 404 FORD LGT 125
I OWN A 2010 JINMA 404. WHEN I STEP ON THE BRAKE AN EXCLAMATION MARK LIGHTS UP ON THE DASH. BRAKES SEEM TO BE WORKING FINE. ANY ADVICE WOULD BE GREAT. THANX , JOE...
/ BRAKE ISSUE #2
First thing with the brake light on, check your brake fluid! Also how firm is the brake pedal?
/ BRAKE ISSUE
THE PEDDLE FEELS PRETTY GOOD. WHERE IS THE BRAKE FLUID RES. LOCATED?
/ BRAKE ISSUE
MANUAL STATES THEY"R SEALED DISC BRAKES, (IN CHINGLISH) NOT FAMILIAR WITH THIS .
/ BRAKE ISSUE #5
No brake fluid, they are mechanical.
Chris
/ BRAKE ISSUE #6
I appoligze. I'm not sure if your tractor has hydraulic brakes or mechanical
/ BRAKE ISSUE
THANX FOR THE INPUT. MAYBE LITE IS SO YOU DONT DRIVE WITH BRAKES LOCKED ON , WITH OUT KNOWING IT ... I 'V E-MAILED A COUPLE OF DEALERS FROM THIS SITE . HOPING THEY"LL KNOW FOR SURE... THANX AGAIN , JOE...
/ BRAKE ISSUE #9
I know there's a starter interlock switch underneath the left floorboard. That's why you have to push the clutch pedal to start the engine. Look beneath the right floorboard for a similar switch on the brake linkage. That's likely what turns on the brake indicator in your instrument cluster. My guess is that it's a "hey stupid" light intended to warn owners not to start moving with the brake pedals still locked in the park position.
2023 FORD F-150 (A60736)
2023 FORD F-150...
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2014 POLAR TANK CRUDE TRAILER (A60736)
2014 POLAR TANK...
WHISPERWATT DIESEL POWERED AC GENERATOR (A60736)
WHISPERWATT DIESEL...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
