Brake controller on tractor
/ Brake controller on tractor #11
Brake controllers are really simple wiring that would be easy to hook up.
The input is just off/on from the brake light switch.
They have 12V positive and negative supply.
And the controller will have output from low to high to the trailer brakes depending on settings.
If you don't have brake lights then you can use a panic button or rig a switch on brake peddles.
2009 PETERBILT 340 (A60736)
2009 PETERBILT 340...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
iDrive TDS-2010H...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
