Brake controller error
/ Brake controller error #21
I have had the same problem with the same controller in my 04 Dodge. I get the error after I run through the car wash and when it wet outside (warm or cold) but seems to last longer in the cold. I've cleaned and greased the connections to the plug with no change. Interestingly when I'm pulling in the rain it has never been a problem (knock on wood). Beyond checking the plug for moisture I have followed the wiring harness from front to back (not as easy as it sounds) I didn't find any damage. I also checked the current output of at the plug when I received the error and compared it to when all was normal and had exactly the same readings. I'll be most interested to know if anyone has identified the problem.
See post #7.
/ Brake controller error #22
i still think it's corosion at the plug cause false signals, as the controller uses brake line power sense to ground to decide if a trailer is hooked up or not..
soundguy
It almost seems like the controller thinks something is hooked up, but since there isn't, it gives an error. Thats why I posted this was to see if I hooked up to a trailer, if the error wouldn't go away. I need to just try it on a rainy day and see if I still get an error or not hooked up to my trailer, but its been crappy and cold with a lot of snow so I haven't tried it yet.
/ Brake controller error #24
my bet is still on a coroded dirty plug or hte backside therof. corosion can pass wek volt signals that might be confusing the controller..
soundguy
/ Brake controller error #25
99/100 its bad/damaged/pinched wiring harness or corrosion on one of the 3 plugs at the plug in (the pigtail plug, adapter plug or the 7 pin socket)
Moisture and vibration cause intermittent faults. That model controller itself is solid state, quite reliable.
/ Brake controller error #26
I have a Tekonsha prodigy brake control in my 2006 Chevy Silverado pickup and had the control not show anything on the screen, I contacted tekonsha on it and they told me to unplug it in the back and leave it for about 60 seconds and then plug it back in. This will reset the controler, and it fixed the problem on mine. Maybe if you try that it will work for yours.
/ Brake controller error #27
I did that numerous times and it always would eventually give error again
