Brake away safety battery"
   / Brake away safety battery" #1
John White
Newark, Oh
Bob Cat Ct335
I am curious as to how many of you maintain your brake away battery, I don't think I ever bought a trailer with it working. Usually that is the first thing I do Is check the brake away system. But don't ask me if I maintain it afterwords. Most time all they need is a new battery but I don't think they will last more than a couple years. How are you supposed to recharge then? Take it out of the box and put it on a charger or is there a way you can charge it from your vehicle? I have been checked a couple times and asked if it works, of course you know what I am gonna say.
   / Brake away safety battery" #2
I’ve never even had a trailer that wasn’t a camper that had a battery on it.
   / Brake away safety battery" #3
All 3 of mine charge when hooked up to my truck and have a test button on them with red, green , yellow lights that show battery condition....
   / Brake away safety battery" #4
I do at least maintain working trailer brakes. You’d be surprised at the people that don’t.
   / Brake away safety battery" #5
Dot requires backup battery if trailer has electric brakes. It should be wired to 12v pin on 7 way connector to maintain state of charge. If your trailer has a breakaway cable for hitching it has a small battery to power brakes if cable is pulled out of switch to stop trailer.
   / Brake away safety battery" #6
The DOT checks them around here all mine work now......
   / Brake away safety battery" #9
Maybe it depends on how often one uses the trailer or has the equipment like Peter 315. Since I seldom use my trailer anymore, I leave the battery in the garage where it gets charged now and then, using a Battery Tender.
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A51248)
UNUSED WOLVERINE...
2013 Ford F-650 Flatbed Truck (A51691)
2013 Ford F-650...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2016 CAT TL642C (A50123)
2016 CAT TL642C...
