Brake away safety battery"
   / Brake away safety battery" #1
John White
Newark, Oh
Bob Cat Ct335
I am curious as to how many of you maintain your brake away battery, I don't think I ever bought a trailer with it working. Usually that is the first thing I do Is check the brake away system. But don't ask me if I maintain it afterwords. Most time all they need is a new battery but I don't think they will last more than a couple years. How are you supposed to recharge then? Take it out of the box and put it on a charger or is there a way you can charge it from your vehicle? I have been checked a couple times and asked if it works, of course you know what I am gonna say.
   / Brake away safety battery" #2
I’ve never even had a trailer that wasn’t a camper that had a battery on it.
   / Brake away safety battery" #3
All 3 of mine charge when hooked up to my truck and have a test button on them with red, green , yellow lights that show battery condition....
   / Brake away safety battery" #4
I do at least maintain working trailer brakes. You’d be surprised at the people that don’t.
   / Brake away safety battery" #5
Dot requires backup battery if trailer has electric brakes. It should be wired to 12v pin on 7 way connector to maintain state of charge. If your trailer has a breakaway cable for hitching it has a small battery to power brakes if cable is pulled out of switch to stop trailer.
   / Brake away safety battery" #6
The DOT checks them around here all mine work now......
   / Brake away safety battery" #9
Maybe it depends on how often one uses the trailer or has the equipment like Peter 315. Since I seldom use my trailer anymore, I leave the battery in the garage where it gets charged now and then, using a Battery Tender.
UNUSED INDUSTRIAS AMERICA 12F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
SAYLOR-BEALL 120 GALLON AIR COMPRESSOR (A51248)
SAYLOR-BEALL 120...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
CIERZO ELECTRIC AIR COMPRESSOR (A51248)
CIERZO ELECTRIC...
