Buying Advice Brain Overload on buying a tractor please help ....
   / Brain Overload on buying a tractor please help .... #11
Most CUT TLBs have the single seat for backhoes and do come off and have 3 point hitches.
I don't mind buying a used unit
was a Yellow flag to me. that figured some explanation was needed. buying used, can get folks into construction equipment vs agriculture equipment. were backhoes are more likely dedicated.
   / Brain Overload on buying a tractor please help .... #12
Reguarding hydraulic pressure. The pump will only put out what is required by the load to do the job. There will be a relief valve that will determine maximum pressure the system can produce. So idle has no bearing. Flow GPM (gallons per minute), will vary with engine speed.
Pressure tells you how much work you can do. Flow tells you how fast you can do it. With Two pumps, one is dedicated to the steering, the other to the hydraulics. The flow for the implement pump is the one to compare.
   / Brain Overload on buying a tractor please help .... #13
I don't have a grapple nor have I ever used one but they are $$ and are you really sure you need one? I guess you have sons, so do like I do in reverse. I sit on my tractor and mom loads the limbs in and across the bucket. I can carry off a very large number that way. Unless you going to clean up and down I4 I think just hauling the limbs off by filling up your bucket might be the best and most economical idea. Use the money you save to buy a new tractor so you don't buy someone elses problems.
   / Brain Overload on buying a tractor please help .... #14
I would seriously reconsider the backhoe. Hiring someone a couple days a year until you get the french drains sorted out will be much more cost effective and how many times are you going to switch out the backhoe and mower? Put that money into a cab with A/C. How hot is it in Florida?
Somebody needs to remind bilrus61 they don't make his model of wife anymore. "I sit on my tractor and mom loads the limbs in and across the bucket." Really? Didn't the OP mention something about SNAKES!!? Not sure a couple of teenagers would be much more cooperative but I guess you could give it a shot. I would get the grapple on a thirty something HP Cab tractor with FEL and mower. Now that I think about it, that's what I did. Good luck!
   / Brain Overload on buying a tractor please help .... #15
While I like my 110 just make sure the height won't be a problem for you as they are kind of tall.
   / Brain Overload on buying a tractor please help .... #16
I would rather have a smaller cab fel tractor and rent or hire the bh work as required. A grapple would be great for what you have described.
Have you looked at tractorhouse ??
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
Deere 410L (A53317)
Deere 410L (A53317)
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
