Oil & Fuel Braided fuel lines
/ Braided fuel lines #1
rdbigfarmboy
Collinwood, TN
MF, Same,Zetor
I have had a problem with Diesel starvation on my Tractor King 404. Changed filters. It would start and run a few minutes loose prime and quit. I called RK they said a common problem was the braided metal lines from primary pump to filter and back to distributor. I pulled the lines off the banjo fitting and replaced with rubber fuel ines and clamps. Runs good But I broke a bleed screw in the process and no must replace it. The braided metal cased lines are not correctly sealed and spin on the banjo fitting.
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2018 Ford Focus (A61574)
2018 Ford Focus...
Kubota L3901HST
Kubota L3901HST
Set of 3 Trailer Tires (A66734)
Set of 3 Trailer...
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
Gravely Pro-Turn 148 50in Zero Turn Commercial Mower (A66734)
Gravely Pro-Turn...
