Box scraping the driveway. Grrrr!!!
   / Box scraping the driveway. Grrrr!!! #21
You guys are missing one very simple thing, box blades are all fine and dandy for spreading out lots of material but if you want to smooth something out nice a regular 3point hitch blade is much better. The fact is you can angle it! That is what will take your washboard out and also you can put a crown on the road with it so water won't sit on your drive way when it rains and it will dry much faster!!
I have TnT on my Kubota. I use the BB 90% of the time. I can control the tailings and relocate material so much easier and faster with the BB than a rear hitch blade. I think the only attachment that will better level ground is the land plane. And for the OP, he doesn't have one of those. So his best bet is to learn how to effectively use the BB. He'll get it figured out.
   / Box scraping the driveway. Grrrr!!! #22
No question that there are better tools, but the OP was trying to remove washboard with a BB that he borrowed. I do wish my BB was capable of angling - tilting alone isn't sufficient for creating a crown.
   / Box scraping the driveway. Grrrr!!! #23
I grew up using only a back blade on roads, but several years ago switched almost exclusively to a box scraper and have similar equipment to ovrszd (Richard) and I can't remember the last time I used a blade.
I believe ovrszd touched on one of the significant details causing the OP problems as his B2620 does not have position control. I own tractors with that type 3PH and it's a bear to control. This makes it much harder, but not impossible. Like most things, it can be done with practice.
I don't disagree with the utility of a LPGS, I just can't justify one as I have a really good box scraper as well as a 10' drag scraper like the one below on my neighbor's tractor that works great for my needs.
   / Box scraping the driveway. Grrrr!!! #24
Who is missing what? The rear blade was mentioned a few times.
Curious if you have a land plane grading scraper, heavy duty box blade, landscape rake and rear blade? I have a large and small of each of these and find the rear blades get the least use. Granted I don't have the best rear blades yet but there is a reason for that too, I don't find I need them enough to spend the money yet.
   / Box scraping the driveway. Grrrr!!! #25
IMO...It is impossible to master (with any efficiency) a box blade without at least a hydraulic top link and preferably a side link too...
FWIW...
This is elementary but some may not be aware...
Most box blades have double (forward/backward) cutting blades...
...With the tractor and BB on level ground...set the top link so that both the forward and rear cutting blades touch the ground at the same time when the 3ph is lowered (neutral)...then make a mental note of the position of the top link...this will help the operator when material is blocking the view...note when either of the blades is set to cut the opposite blade is slightly off the ground and vice versa...
I have found the best way (my experience) to evenly distribute collected material is:
Set the forward blade aggressive enough to cut/collect material...when the box is full or the cut line is reached...lengthen the top link to set the bb back to the "neutral" position then pull the material to beyond the area to be filled and drop the load...pull ahead so the BB is ahead of the material...
...now set the forward cutting blade back to a slightly aggressive position (this will keep the rear blade from cutting)...lower the 3ph so the forward blade is at the desired depth of fill above the grade...then in reverse push the material backwards over the area to be filled...
...This works (for myself anyway) much better than trying to spread material from inside the box by judiciously raising the 3ph while passing over the fill area...It also eliminates the undulations (whoop-ti-doos)...
   / Box scraping the driveway. Grrrr!!! #26
Lots of good stuff in this discussion. Interesting to hear how different guys approach the problems differently.
[/Pine'sB] description above is very good. With a hydraulic top link it's extremely easy and fast to make those adjustments.
Going forward with a loaded box, and wanting to start dumping, I extend my top link and let the material slide under the front blade. The reversed rear blade then starts riding up over the material evenly spreading the load and filling whatever dips are there.
Someone mentioned crowning. With a hydraulic side link that is very easy to do with a BB and leaves no row of tailings that you tend to get with a rear blade.
Another point to consider. On all 3pt attachments the cutting edge is "outside" the tractor's track. What I mean is the blade, rather than being between the front/rear axles like a commercial road grader, is behind the rear axle. That's why the front axle movement has such a large impact on what the cutting blade is doing. Sometimes causing the dips and humps that we all complain about.
A BB minimizes this because the cutting blade is relatively close to the rear axle. On a 3pt rear angling blade the cutter is much farther back. So when trying to slightly carry the rear angle blade with loose material onboard any movement of the front axle has a more dramatic effect on the result. A rear angling blade is at it's best when it's allowed to ride along on the ground with no 3pt tension on it. That's fine if, #1 your blade isn't heavy enough to cut excessive material. #2 all you are trying to do is move loose material back and forth across a surface such as a good roadbed. If trying to level grade material the BB will outwork it easily.
Larry's 10' drag scraper is a very good tool in the right hands. Especially if it has hydraulic tilt on one wheel to tip the box. If you look at his picture you see what I mean about the cutting blade being between two axles. What the front axle of Larry's JD does has very minimal impact on his drag scraper. So when he hits a hump with the cutting blade it tries to cut it off with no input from the operator. Or when the box is full and the blade comes to a low spot it automatically dumps material, again with no operator input. Makrs an inexperienced operator look like a professional. And the best part is it will move material a considerable distance.
Fortunately for us "challenged" operators, there are a multitude of tolls available. And at least one of them will make us actually look like we know what we are doing.... :D
   / Box scraping the driveway. Grrrr!!! #27
I'll up that to 99% of the time. The other 1% of the time my wife is using the brush hog in place of a therapist. I do have a hitch blade, but it was given to me. It's been sitting in the same spot next to my shop for over five years, so I'm glad I didn't spend any money on it. I also have a land plane, but for the most part it sits right next to the blade. I'm not saying a blade or land plane doesn't have a purpose. But, I regraded a bunch of driveways and parking lots and placed over 4000 yards of gravel last year. That and a few miles of swale grading. I don't find much that I can't do with a bb.
   / Box scraping the driveway. Grrrr!!! #28
So if my wife is in an ill mood I can help her get over it by hitching up the brush hog and turning her loose?? ;) :eek:
I had been wanting TnT for a few years. Just before I retired a Contractor replaced the hiway and sidewalks in front of my Army Center. They finished the dirtwork with an old Case industrial loader tractor with a 3pt Gannon BB and TnT on the back. I went out and watched this young man work for about 30 minutes. I was sold. As soon as I got my M9540 I added TnT. Amazing what can be done in experienced hands. I run a road grader so I'm a bit picky about smoothing material. Sometimes I struggle a little to achieve the standard I'm after but with patience it can be done. :)
   / Box scraping the driveway. Grrrr!!! #29
Yep...my wife says its good therapy. I'm not about to argue. I get home from grading all day on my ctl and the tractor is sitting there with the brush hog attached and pasture mowed. She even runs the loader and bb pretty dang well.
I hear you on the industrial tractors. I cut my grading teeth on old IH, JD and Massey skip loaders (industrial tractors), cutting swales and spinning out pads in the 70's, long before skid steers hit the scene. We thought that skid steers were a kind of weird passing fad. Running the bucket with your feet?...now that's just goofy! (I still think it is.)
   / Box scraping the driveway. Grrrr!!! #30
I'm with ya on that foot thing. My Brother had a Bobcat T300. You could run the bucket with the treadles or joysticks. I always ran it by joystick. He always ran it by treadle. I could do smoother work faster than he could. He wouldn't accept that I was a better operator so I always teased him about using the treadles. I use my feet to plant myself in the seat, how am I supposed to run the bucket while doing that??? :)
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Forklift Safety Basket (A56857)
Forklift Safety...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
