box scraper - what size?
/ box scraper - what size? #1
tractor_man
I have a John Deere 4210. The width rear tires is 58 inches(outside to outside), the width of the front loader is 63 inches. I am going to buy a box scraper, should I get the 60 inch or the 65 inch box? What are the advantages / disadvantages of each?
Thanks for your help,
Dave in Sacramento
/ box scraper - what size? #2
Get the 65 inch. That way it will cover outside of the left and right tire tracks, even if you are turning slightly.
Will there be any difference in performance taking into account that my tractor only has 28 hp?
Thanks,
Dave
/ box scraper - what size? #4
Tractor_man,
I have a JD 4200 and the 65" Frontier box blade. The 28hp handles it, providing you are not trying to perform massive excavation in hard packed clay. Advantages of the 65" are you cover the tracks and have a couple inches on each side if you are trying to grade close to a fence or building. The only disadvantage I can think of is a few lbs of additional weight (22 additional on the standard box blade) which isn't material when you are talking about a 500 lb implement.
Bill
/ box scraper - what size? #5
As Bill says, it's only a few pounds heavier so that won't make the difference. You'll take a 65" "bite" of earth instead of a 60" bite, so it will work your tractor about 8% harder. But that probably won't make a difference. If it does, you can make 13 passes instead of 12, and grab 60" of fresh earth and 5" of what you just leveled on the last pass. In other words it can't hurt you. But most of the time you'll probably be fine with the full width working.
That said, the advantages of working where your tire just went over is a compelling advantage. I think that's why they make the 65" model, since so may compact tractors are about 60" wide.
I've attached a picture of my 65" box blade shortly after I lifted it off the truck that delivered it.
/ box scraper - what size? #6
Hi dave--I know shipping is a factor but here is our First Choice in the 6 ft model at $450 + shipping--Just food for thought--I am sure you can beat that price locally even with the sales tax added--Ken Sweet
Sweet Farm Equipment Co *Since 1977*
/ box scraper - what size? #7
Here is some more Food for thought. The Real Thing a Midwest BB20-72 Red for $325+ freight, with free lift gate service to most of the USA.
/ box scraper - what size? #8
This is getting pretty interesting. Are there any others offering box blades out there? I have been thinking about getting one for my TC-40D as well. It's about the only implement that I have been borrowing from a neighbor when needed and that gets old real quick. Anyone offer a New Holland blue in the powder coat finish? /forums/images/graemlins/smile.gif
/ box scraper - what size? #9
Check out the Corriher eBay Store. I have the BB48 model. Very well built. Wish I went with the next size up, though it might be a bit hard on the tractor.
Corriher eBay Store
Skeleton Backing Plate (A62679)
Skeleton Backing...
Location Tampa, FL (A61567)
Location Tampa, FL...
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
(5) Steel Wheels (A65640)
(5) Steel Wheels...
