Box Scraper Problem
   / Box Scraper Problem #1
DIRTCUTTER
New Mexico
CK30 HST
CK30 HST with fel and bh 65hrs. I just added a 4ft box scraper after using it for about 3hrs its very slow coming back up, i mean real slow. I let it set for an hour, still very slow coming back up. All this happen with the control set on the rabbit position.I installed it according to instructions. Is there another adjustment that I dont know of.
   / Box Scraper Problem #3
That sounds like more of a 3pt hitch problem and not the BB. Is the BB caked in heavy soil that could add a lot of weight to it ? Try unhooking the BB and see if the 3pt hitch raises at a normal rate with no weight on it.
   / Box Scraper Problem #4
   / Box Scraper Problem #5
Are you raising it at idel speed or a higher rpm? If you are at idle it will raise very slowly because the low hydraulic pressure. Your hydraulic pump is turned by the engine. It will drop quickly because of the weight of the scraper even at idle.
   / Box Scraper Problem #6
Yes am using high rpm. could low fuild level cause this problem?.
BB box blade is that right. Its clean , same problem am going back out and take it off and do what you suggested.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Truck Bed or Trailer Cargo Tarps (A47384)
Truck Bed or...
John Deere 825I Gator (RUNS) (A50774)
John Deere 825I...
10' Poly Feed Trough (A50515)
10' Poly Feed...
CAT 963C (A47384)
CAT 963C (A47384)
