Box Scraper Problem
   / Box Scraper Problem #31
Is your problem limited to raising the BB? What about other implements on the 3PT? Do they lift appropriately?
   / Box Scraper Problem #32
   / Box Scraper Problem #33
Hmmm, sounds like a trip to the dealer if it doesn't raise w/out the scraper.....let us know ehat happens.
RD
   / Box Scraper Problem #34
RD
   / Box Scraper Problem #35
What are you using to get hydro fluid to your BH? The hose kit with the valve you have to turn from under the tractor or do you have the actual remote valve that has a lever by the 3pt lever? Kioti John hit this point but I wanted to stress it again. If the valve under the tractor isn't fully turned/seated in the proper direction, for the 3pt it's counterclockwise, you won't get full power back to the 3pt. It takes a good two full turns until it stops.This was another live and learn for me and my CK30hst.
I hope that's all it is. There isn't a QD going to the 3pt. It's all internal and nothing else to turn or adjust. You want to make sure the hydro oil is at least up to the lower mark on the dipstick.
   / Box Scraper Problem #36
Problem solved,with the help of kiotijohn. The shaft I was looking to control the fuild to the 3pt. is located just rear and above the hydraulic filter it looks like a small drain plug. Its in the middle of the valve that has two hoses contected to it, these hoses are used for the backhoe. I used a # 11 wrench, to turn the valve clockwise and got nothing, then turned it counterclockwise that worked. I now have normal lift on the box blade. When I reattach the BH I have to re-adjust the valve. I hope this helps but if you need help let me know . If you have a remote switch this does the fuild adjustment for you.
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2017 Genie GTH-5519 (A53317)
2017 Genie...
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
