Box Scaper Questions
   / Box Scaper Questions #11
"Beside solving the short arm problem, it is so much handier for everything else and you don't have to worry about shortening PTO shafts to keep from bottoming out the side and tearing up the u-joints. "-That should have read-
"Beside solving the short arm problem, it is so much handier for everything else and you don't have to worry about shortening PTO shafts to keep from bottoming out the SLIDE and tearing up the u-joints. "
   / Box Scaper Questions #12
mtg65 said:
I found a slightly shorter top link, which I was able to make even shorter. The one I modified is now about 2 1/2 inches shorter than the original and it makes a huge difference! I am able to tilt the box forward (like yours 3rrl) and it grips and rips. Does a nice job.
I am also going to add more weight as suggested and eventually the Pat's EZ change system to cut down on the 3pt hitch up aggravation::D
Way to go...
You are good to go now.
1987 GMC C7000 Firetruck, VIN # 1GDM7D1G3HV526472 (A57453)
1987 GMC C7000...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
DEUTZ MARATHON...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
