Forks Box on pallet forks
   / Box on pallet forks #1
LHS Inc
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
I'm getting a set of CA Pallet Forks from Everything Attachments in a couple weeks for my JD 3520 300CX FEL.
I was was thinking about some sort of container type box something like a 3-pt carry all box I could scoop up with the forks and use to haul and dump light bulky materials such as sticks, limbs, and leaves within the loaders capacity.
Just now I have a yard to clean up from Huricane Irene and this sort of contraption would be perfect for the job.
If I had some larger limbs to move I could drop the box and lift/haul away with just the forks.
Just a rough idea would be a sheet of plywood bolted longways across a heavy duty pallet with some sides and back. All lumber would be pressure treated except for the pallet.
Maybe this has been kicked around already but I'm new to it.
Thanks for any input.
   / Box on pallet forks #2
Could be handy but be aware that there are a ton of manufactured containers for this used in industry/warehousing - see this google image search for examples. You may be able to find something used that is cheaper and stronger. I'd think about how to dump it too - some sort of lock mechanism to keep it on the forks might allow for dumping with the forks.
Thanks for your reply. Yes I was thinking of chains or something like that to secure it to the bracket on the forks so I could dump the load and take off if I need to use just the forks.
I checked the google link. Something like that would be great.
   / Box on pallet forks #4
For more ideas, try a Google image search for
forklift dump bin
and
forklift dumper
   / Box on pallet forks #5
If there is any manufacturing in your area, look around for small wooden crates that have fork pockets in the bottom. Where I work, we toss these all the time. Very handy for everything from clean-up to firewood.
   / Box on pallet forks #6
If you will use it on a FEL you won't really need the dumping feature because you can just use the curl function to dump, same as you would with a loader bucket.
   / Box on pallet forks #7
Get a toothbar, the projection of the teeth give enough of a cradle to support a big pile of branches. You can haul them away and raise the bucket very high onto a pile, then use the bucket to compact the pile down. Works like a charm. I have a lot of branches to clear from Irene, I will take a picture showing how much I can stack onto the bucket.
   / Box on pallet forks #8
Used pallets are easy to find free...just get one and build onto it what you want/need. Have you checked out the forks sold by Artillian?
   / Box on pallet forks #9
I made a box to handle my leaf collection, I just used the plywood and 2x4's on the bottom to keep it tight then a threaded rod bent into a J shape to grab the fork frame and pull the box in tight. It's basically an 8ft wide bucket now, I kept mine low by not using the pallet so I can drive it under a pile and scoop it up to make loading it easier.
Works great and saves time by eliminating handling the leaves as many times as other methods. One guy here on TBN has one similar and he added a gate on the front to hold even more debris.
JB
   / Box on pallet forks #10
JB,
The leaf box looks great.
I was really more impressed by the edgeing between your gravel driveway and the grass, very neat job there.:thumbsup:
2013 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2013 FREIGHTLINER...
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
BFH 1000 BALANCE FORCE HARMONICS TIRE BALANCER (A54757)
BFH 1000 BALANCE...
1981 LOAD KING BELLY DUMP (A55745)
1981 LOAD KING...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
