Box Blades, or Box Scrapers for a 186D ?
   / Box Blades, or Box Scrapers for a 186D ? #1
Pete Judd
The Thin Gravy Ranch in The wet PNW
Yanmar 186d, JD 314
I have been looking at several, and wondered about the fact that the 3ph has no down pressure, to these work well? Or do you just use the weight of the tool to do the work? Just does not seem right, since I used to run heavy eqpt. years ago.
   / Box Blades, or Box Scrapers for a 186D ? #2
The weight of the implement is all that is needed. I run a 4' box blade and 5' straight blade. I have never needed to add any weight to the implement.
   / Box Blades, or Box Scrapers for a 186D ? #3
Yep, blade weight and angle of cutting edge or scarifiers, (top link length), does the trick.
   / Box Blades, or Box Scrapers for a 186D ? #4
Pete,
You can change the angle of the cut,using the top link, so that the cutting edge actually slices off and lifts the material. With my heavy 4 foot BB I have no problem filling it, getting enough traction to pull it is my problem. With my RB I mostly am moving snow or leveling out loosened dirt, so it also is not a problem. You can check out what mine look like in the links in my signature.
There are times that I would like some down pressure, but remember the old cable dozers also just used weight to get the job done.
Mike
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
