box blade ?
/ box blade ? #11
I'll second what MR and Kent said. I don't own a box blade, but find that with the 4 in 1 bucket 'back dragging' with the blade open to cut, and closed to smooth in 'float' give really good results in the same way with multiple high speed passes.
Varying the angle of the blade helps feather edges of scraped areas, also, as the blade nearly parallel to the ground (when going backwards) moves much less material than with the blade nearly vertical.
High speed is, obviously, a relative term. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Mark H.
/ box blade ? #12
Mark H.
/ box blade ? #13
Having only used the rake, buckets and mowers in reverse on the PT, I would need a lot of practice to get the hang of using a box blade in reverse. It feels more intuitive going forward.
It would seem that having draft control, like on the 14xx and 18xx units, would make for easier management of the depth of the blade (Any red machine box blade users confirm this?). Operator wouldn't have to choose between float or some arbitrary depth that might wind up too shallow or too deep.
Of course, if you are "da bomb" like pajoube, you don't need no 3-pt hitch and no stinkin' draft control /forums/images/graemlins/grin.gif
/ box blade ? #14
/ box blade ? #15
>>>Of course, if you are "da bomb" like pajoube, you don't need no 3-pt hitch and no stinkin' draft control<<<
Sounds like someone has been watching American Idol. /forums/images/graemlins/grin.gif
/ box blade ? #16
/ box blade ? #17
The draft control in my 1445 doesn't maintain a certain depth. It provide intermittent amounts of hydraulic boost to the arms to lessen the weight on say, the mower deck. Before I figured out how to adjust the draft control I always used the mower deck in float. The combined weight of deck and the arms would cause the tires to literally come off their rims. Draft control would lessen the downward force on the box blades and make the blade less efficient.
/ box blade ? #18
/ box blade ? #19
That's the same way draft control works on a standard 3PT hitch... you are traveling along with the implement engaged into the soil. The implement hooks up to some harder soil, the rear tires start to rotate the tractor front end up, which causes the top link to push back against the implement. Since it can't go anywhere, it wants to push back on the tractor. The top link is connected to a rock shaft on the tractor. When the rock shaft is rocked, it triggers a valve that lifts the implement out of the soil until the rock shaft returns to its normal position. As it returns to its normal position, the implement is lowered back into the ground. However, with the one I had on my old IH, that usually meant the impelement would bounce up and down all over the place, because something was gummed up in the valves! /forums/images/graemlins/tongue.gif
/ box blade ? #20
2020 DRAGON ESP...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
