Grading Box Blade
/ Box Blade #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
I've been able to use the new box blade I purchased at rick's at the cookout.
This is one of the best ground engaging tools I've ever owned. Superb at rock farming, grading and leveling.
Not much else to say, if you've ever considered one, I would not hesitate.
My woods is excellent.
Sincerely,
Joel
/ Box Blade #2
You've got that right Joel! It's the first implement I bought when I got my first tractor. It's commonly found on the back of my Jinma, and will be a regular on the Kioti. I even use mine to skid logs, as you can wrap the chain around the ripper bar, and lift the logs up and into the back of the blade. I'm sure you'll come up with a multitude of uses for it!
And the potential for "damage" is much less with the box blade than with a dozer!
/ Box Blade
Good point on damage. Those rippers are purpose built and there is nothing better I've used at getting rocks out of the soil.
A really great tool.
/ Box Blade #4
Which one did you get? I picked up a used woods GB-60 box grader, the paint wasn't even scratched. The guy said he used it 3 times over 2 years, then sold his tractor and bought a bobcat skid steer. I got it for $400. Haven't had time to try it out yet. Glad to know that it works well on getting rocks out.
/ Box Blade
That's the woods model I've got. Great tool, paid twice the price new, still no regrets.
Joel
/ Box Blade #6
Thats good to know. I got very lucky on the price, he said he hadn't really shopped it around and wasn't sure what to ask for, thats when I said "how about $400" he paused for a little bit, then agreed. I had been looking for a while and most of the prices I got for various brands was $600 for a light duty up to $1000. So I figured I made out pretty good, just can't wait to use it.
/ Box Blade #7
Fine, I get it already, so I need to get one of these. hmmmm
I actually have a set of rippers, I wonder how much effort it would take to make one of these... :D
Now if only I still had my good welder... :(
/ Box Blade #8
Joel, what are rocks up your way? I find plenty of 12 inch diameter just at the surface. Is the BB going to pull these up OK or is this asking too much. Of course, I'd be breaking the sod at the same time.
Maybe you are describing a cultivated field and the annual harvest of frost heave rocks?
I havn't been brave enough to take the BH off yet, but when I am, I'll give the BB a try.
/ Box Blade
if your tractor is heavy enough you'll have not problem, I'm pulling up rocks bigger than that, a couple of passes on some occasions but they come up.
The big big rocks get backhoed or dozered.
Joel
/ Box Blade #10
Think about what you're saying here. Raking 12" rocks? That's like a basketball. Do you even have that much clearance under your front axle? To get your ripper teeth under a 12" stone that is level with the surface you'd need to have the sides of your box well into the soil. This sounds like a case of a fish "this" big. You could pop out one 12" rock with a wood bit of effort and creative BB work but the B is snot the right tool for picking hundreds of them.
Now a dozer with a rake, that would be nice to remove them. Then scoop them off and haul them away with your DK.
/ Box Blade
Agreed on the dozer with a rake idea, our washington buddy had a nice set up (before he sold it) ):
I've pulled rocks a whole lot bigger than a basketball out of the ground with my boxblade with rippers though.
Been thinking about welding up a rake for my dozer. Would be tough going on my little machine though.
Joel
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
211453 (A62131)
211453 (A62131)
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2008 Ford F250XL, Crew Cab (A62679)
2008 Ford F250XL...
Grass Seed (A65640)
Grass Seed (A65640)
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
