Box blade technique.
/ Box blade technique. #1
tbohen
Central Michigan
Kubota BX22
Ordered my kubota 7548 48" box blade for my BX22 and it should be here the first of the week. My first job is fixing a buddies yard around a newly constructed garage. Basically I will need to haul in some black dirt and then regrade so he can plant grass. Any helpful hints for a guy thats never used one before? Thanks
/ Box blade technique. #2
I hope lots of others chime in with tips 'cause I can always use more /w3tcompact/icons/wink.gif The most important thing in my book is to go s l o w l y when using the box for grading work. If you go too fast you can't compensate the tph quickly enough and every little whoop in the terrain will be multiplied as the box digs in or dumps a load. If you go slowly (I'll use low-1 at low RPM if I need) you can keep an eye on the box and raise/lower it to ease the whoop-d-doos.
Again, I hope others add to this, I'm hardly an expert with the mystical box blade /w3tcompact/icons/smile.gif
/ Box blade technique. #3
I'd suggest experimenting some with the 3ph linkage before expecting too much, especially the top bar. The more you shorten the top link the more the blade will dig-in. When the front of the tractor goes up it pushes the box blade down, causing it to dig-in even more, and you end up with a wash board.
Extending the top bar decreases the bite of the blade and allows you to drag and spread without cutting into the base, but doesn't allow you to shave humps in packed soil.
Since it sounds like you will be spreading loose dirt, extend the top link to start with the box tilted back slightly, and then gradually shorten the bar as you get the feel of it.
Kelly
/ Box blade technique. #4
First make an appointment with a chiropractor for the following day (your neck is going to need an adjustment.)
Tell your friend and any other witnesses to plan a round of golf or some other diversion for that day.
Take a dose of "darnitall" before starting and don't blame the box blade.
Buy a good shovel and hand rake to finish the job.
Sorry, couldn't help myself. That would have been unwelcome but realistic advise for me when I first got mine.
It will take many hours of practice to get efficient with your equipment. Do not be discouraged, do not rush, be careful, and the next time you see a bonehead on a tractor making a job look easy you will have a new found respect for the operators skill and experience.
/ Box blade technique. #5
<font color=blue>My first job is fixing a buddies yard</font color=blue>
Hope he's a patient buddy.
Actually, it sounds like an excellent project to begin the box blade learning process on. It's a seemingly simple tool to use, but it takes lots and lots o' practice to start getting the results you're looking for. Don't ask how I know.
What kind of shape is the existing landscape in? If it's relatively flat to begin with, you should probably do fine. But if it has peaks and valleys and it is at all hard packed, you've got your work cut out for you. As others have already mentioned, the height of the blade will vary as the tractor itself climbs and drops over uneven surfaces. There are times when you'll do better, at least on the first pass, by using the FEL. Any time you can keep the tractor on the already-graded surface, the better chance you have of bringing the rest of it into line.
Will your box blade have rippers? Often times you'll need to break up the high spots before you can begin the leveling process. That's when rippers (scarifiers) or a toothbar come in handy.
Once you have the general terrain the way you want it, spreading the new black dirt should go fairly smoothly. Might be a tedious part of the learning curve, getting a feel for the angle and height of the blade just right, but if you take it slow enough you'll have hours of therapeutic seat time.
Oh -- and you'll find that these things are much more satisfying if you take lots and lots of pictures to share with your TBN buddies. /w3tcompact/icons/grin.gif
/ Box blade technique. #6
Glad you started this thread.
I believe I have a box blade ordered (Frontier 60") and an iMatch to attach it too. Now, after renting a 60" tiller, I am having second guesses as to what to buy.
I found out when renting a box blade (after I ordered one) that it wasn't as useful as I thought it might be. I was trying to scrape up some black dirt that was under sod, and move it to an area that I wanted to fill in. The chunks of sod, even though I used the rippers, were too large to move around easily. And the box blade didn't seem to work as well as my rear blade. That is when I rented the tiller. I tilled the sod and then used the FEL bucket to move and spread the tilled sod and dirt. It worked great. The tilled sod had some fresh grass roots that took off right away, along with grass seed on top.
Now I am in a dilemna, and am not sure if I will go ahead and get the box blade (renting the tiller for future work), or just buy the tiller and use it in combination with the rear blade and bucket. Regardless, I will get the iMatch and convert the rest of my attachments to fit the iMatch.
My expectation with a box blade is that it takes a lot of passes back and forth to end up with a finished job. IMO, trying to do a job quickly will be frustrating at best.
/ Box blade technique. #7
I would add that if you drag it through any large rock with the scarifiers down be prepared for flying rock chips. In fact I would suggest wearing a hard hat and goggles unless you like your head pelted with rock. When the teeth break the rock it seems to explode and pieces go everywhere. In grading a ditch I had this happen a few times and was suprised to see the amount of rock chips that had accumilated on the back of the tractor. I also got a nice big bump on my head. This is a big eye hazzard.
/ Box blade technique. #8
<font color=blue>When the teeth break the rock it seems to explode </font color=blue>
Now that's an interesting phenomenon.
Guess it depends on what kind of rocks you have. I have plenty on my property. Enough so that working the soil is almost always a frustrating experience, but all that happens to me is that the rippers either break it loose or skip right over it. If the size and shape are just right, they can even bring my tractor to a rude and abrupt halt. Hate when that happens. /w3tcompact/icons/tongue.gif
Not exactly sure what you'd call the kind of rock I usually deal with. Lots of iron ore in them, and there's plenty of granite nearby (I don't even try to work the granite areas), but I don't ever recall having one "explode" or anything close to it. Never seen or heard anything hit the back of the tractor.
When ripping, I'm always in the lowest one or two gears (manual shift) and going real slow. I assume that's the same for you?
/ Box blade technique. #9
Because the Kubota 7548 boxblade is the swing back type it works best to spread while in reverse with the top link shortened some. Operation of the fixed back and swing back type are slightly different. I would prefer a fixed back but alas I have the 7548 also. J
/ Box blade technique. #10
Harv,
I use the lowest speed range on my hydromatic transmission for ripping with the box blade and move at a very slow speed. I also sometimes catch on rocks that stop the tractor or rather cause the wheels to hop which is something I don't like to do. I am sure the type of rock has a lot to do with how it behaves when it breaks under pressure. It probably also is affected by the size of the tractor and the weight of the box blade. All I know is I got a few knots on my head from larger chunks of rock and lots of rock chip all over the back of the tractor when I graded one of my ditches.
/ Box blade technique. #11
<font color=blue>It probably also is affected by the size of the tractor and the weight of the box blade.</font color=blue>
Yeah, I was thinking about that after my last post, Don. Your equipment is much bigger, heavier and more powerful than my li'l 'Bota. But then, everything in Texas is bigger, huh? /w3tcompact/icons/laugh.gif
I'd never heard of it happening before, but now I have. Just glad it hasn't happened to me yet, and glad you're still around to tell the story.
/ Box blade technique. #12
Try lowering the two outside ripper teeth down to a position about 2-3inches below the plane made by the bottom of sides and blades and let them drag as you are going backwards. I believe that is the best way mimic a bulldozer.If the ground is hard, tilt the toplink out to decrease the backblade/ground gap, if soil is soft teeth will gravitate deeper in soil so tilt toplink in. If you adjust all teeth to drag that way, you are susceptible to more bumps that will raise the box.
If you are in the boonies with out a jack and need to service the rear tire(s) and you have a loader and MFWD,fill your bucket with dirt and carefully back into and immoveable object with a boxblade in float. With enough traction the front tires will push the back tires off the ground. I just learned this yesterday on accident.
/ Box blade technique. #13
A technique I discovered useful for using a boxblade was kind of by accident. Others have discussed a washboard effect caused be the back or front wheels entering a dip. I noticed if I final grade in a circular or figure 8 pattern, that most of the dips/washboards are eliminated. I believe this is because the box blade now works in an angled manner and both the tractor and blade tend to float over the ground easier.
I also believe that top-N-tilt makes the problem of getting the right grade much easier.
/ Box blade technique. #14
tbohen,
If you can get a hydraulic toplink. Its a must have when using
a box blade.
- GO S L O W! GO S L O W. I keep my tractor in range A(low) and
in gear 2. 1 is lowest 4 is highest.
- TURN ON MFWD if you got it. MFWD makes a HUGE difference when
pulling dirt. Without MFWD turned on, my tractor can surge as the
box blade hits rocks and roots.
- Rip the ground first if you have lots of rocks. Then smooth with the
back of the box.
- Its often easier to smooth things by going in reverse if you have a box
that has a blade on the rear.
This last weekend I started smoothing and finishing my driveway to be.
It took a few hours to do 500 feet plus a turning circle that is about 60
feet in diameter. HEAVILY rocked soiled. I have driven the driveway
with the truck and it was a bumpy ride. Drive the wifey's Jeep up the
road after most of the rocks where removed and the driveway was
smoothed out. She still thought it was bumpy but it was a huge
difference after I spent a few hours working it.
Take your time.
A hydraulic toplink really makes this easy to do....
Good Luck,
Dan McCarty
/ Box blade technique. #15
Harv,
<font color=green>everything in Texas is bigger, huh? </font color=green>
Only the longhorns (cattle that is). One of my neighbors or I should say several of my neighbors have longhorn cattle and I am always amazed at the size of the horns on those things even though I have been around them all my life. My cattle are polled because I don't want to be near anything that looks that wicked!
Thanks for all the tips everyone, I hope to put them to use this weekend. I'll post whether or not I actually figure it out :)
/ Box blade technique. #17
I agree with the guy who pointed out that a rear tiller does a great job, particularly on sod or compacted soil. I just did some areas on a road bank on my property. Used the tiller to pulverize the soil, then backbladed with the FEL to finish grade it. Worked great. Not only that, but the tiller tends to smooth things out because the heavy tiller door dragging on the loosened soil acts like a grader. I have even worked my gravel drive near my barn this way. The gravel is, however, hard on the tiller tines.
By the way, my JD 750 has these slots at the bottom of the two lift arms that can be adjusted to provide "float" to rear mounted implements. You reverse a piece of steel and the implement can move up in down in the slot a few inches. Reverse the steel and the implement cannot move up and down in these slots. I have never heard anyone here on TBN discuss these things. An old timer at the local general store where we gather for coffee in the morning put me wise to this.
Anyone out there making use of them?
/ Box blade technique. #18
My 790 has the slots in the tph also. The manual calls it "lateral float". I use it for everything except bush-hogging. Before I discovered the feature I would get a lot of gouging when using my box blade and rake. With the lateral float, the implements follow the contour of the land with little or no gouging. I suppose there are instances where you want to control the lateral tilt but I haven't had to yet /w3tcompact/icons/smile.gif
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2015 Dodge Journey SXT SUV (A61574)
2015 Dodge Journey...
2006 Ford Crown Victoria Sedan (A61574)
2006 Ford Crown...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2017 FREIGHTLINER CASCADIA  6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2017 FREIGHTLINER...
