Box Blade size for kioti ck2510
   / Box Blade size for kioti ck2510 #11
For another comparison, I've pulled a 5-ft. Howse box blade (around 400 lbs) behind my little Kubota B2150HST (24 hp, about 2300 lbs with loader) for many years. Mostly maintaining a 3/4 mile access road of crusher run. Even with a full box of wet stone, I've never had a problem in medium range.
Sneaky001, I need to make a correction to the above post, in case you use it as a another data point. When I said the overall weight of my B2150HST with loader is about 2300 lbs, I forgot to add the weight of the liquid ballast in the filled rear tires. :duh: They are large turfs, so that's probably another 550 lbs. So the total weight of 2850 lbs is closer to the 3000 lbs of your CK2510. As you know, more tractor weight usually means better traction, plus the benefit of inertia once you're underway. For ground engagement work, loss of traction often occurs before the engine bogs down. So weight can be more important than hp.
thanks for all the very helpful replies.
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
Massey Ferguson 9250 (A56436)
Massey Ferguson...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
JOHN DEERE TRACTOR (A58375)
JOHN DEERE TRACTOR...
1994 CAT 322L (A55272)
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
