Grading Box Blade Question
   / Box Blade Question #41
dbdartman said:
Just back for the JD dealer, with sticker shock. The Frontier BB2065 (5'5" wide HD) lists for $1043! :eek: We agreed that's too much & he's going to see what he can find in the same size & $7-800 range for me.
Any suggestions on other dealers I should check, remembering that I'm in NJ (not interested in a good deal that goes bad with shipping cost).
I paid 50% more than that for mine.....but it had a shipping weight of 880 pounds and all the goodies except hydraulics.
jb
   / Box Blade Question #42
Just back from today's shopping. Priced a new Brush Hog brand (5' 6", 510 lbs) at $700, & a very slightly used (dealer graded the lot/drive with it a couple times) Befco (5' 6" 525 lbs) at $700. I have 3 other places to check in the next couple days.
So far it seems the Befco is in the lead, followed closely by the Hog. If I can get the Befco for $650 cash, I think I'll jump on it (although the price to start was $750 until he saw some paint worn off).
Updates to follow. Comments, as always, welcome.
   / Box Blade Question #43
Haven't left the house since the last update, been way too cold & WINDY! Looked at the Land Pride 72" today (no 65"/66" available). Nearly $900. :eek: Going to check on a tractor/implement sale at a local farm tomorrow that I was told about late this afternoon. Sure hope there's a box blade (or 3) available! I'll keep my fingers crossed....
   / Box Blade Question #44
Hmmm, some 4" x 1/2" angle iron, some 3/8" strips, 1/2" plate, couple grader blades, a bit of time on a CNC laser cutter, ebay sells scarifiers for box blades...
jb
Well since my last post took delivery of my 66" United BB. I used it to attempt, yep "attempt" to grade out the load of "chirt" they sell here in my area. This is a mixture of a reddish clay, sand and small rocks. I put this stuff, I should say crap (it is sticky-sticks to your shoes like glue when damp), as a driveway base. Will put crushed stone gravel over it eventually. One thing I did summize is that it should spread better when it is completely dry, but won't know that until it drys out maybe in the spring or summer!! It has been very cold and wet here in middle Tennessee. Not used to this comming from south Mississippi where it is winter one day and summer the next.
   / Box Blade Question #46
Well, after agonizing over it for a couple weeks, & coming to the conclusion that since the soil here is mostly sandy loam with no rocks, plus I'm a pretty accomplished welder/fabricator, I decided on the "light duty" KK 72" from Tractor Supply. If I bend/break anything on it, I can fix it. Couldn't really justify the extra $200 for a heavier ones, based on soil type & intended use, so...
Just returned from the 150+ mile round trip to Vineland, NJ with the new toy. Maybe I should consider removing the cap from the back of the old Ford permanently. It made loading & unloading the box blade... interesting. Oh well, got it on & back off without breaking/bending anything, so, let the fun begin! :)
   / Box Blade Question #47
I have a 60" ipull all over my 3 acres. It just take pratice. If the ground is wet, your almost wasting your time. The dirt/mug will just ball up ang not spread very good. Wait for it to dry, play with your top link to get the rigth angle and ride a lot.;)
   / Box Blade Question #48
A quick question.
Can Cat 1 3pt implements be attached to a tractor with only a Cat 2 3pt. Is there an easy way to do this as Cat 1 implements are lower cost or am I offbase on this.
   / Box Blade Question #49
You can buy bushings to convert from cat 2 to cat 1.
   / Box Blade Question #50
Thanks John. I will look into it More.
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A55315)
2023 Kubota...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2022 Coras Predator Steel End Dump Trailer (A55315)
2022 Coras...
