Grading Box Blade Question
   / Box Blade Question #31
Looks like a 66" wide it is. Good to know at least SOME of the questions I should ask (rear blade & weight).
Lone, We'll see what kind of price I get from the JD dealer (about 15-20 minutes away). Hope it's around $700!
John, thanx man. Those suggestions are a BIG help!
E-Mike, that's just my "toy", a '68 Dart 2dr sedan. One of these days I'm dumping the flashy wheels for a set of painted stock steel ones & hub caps to complete the "sleeper" look. Da(i)rt was actually built to chase Corvettes through the back roads, so all the "tricks" are in the suspension, steering, & brakes. You can read more about it in http://www.tractorbynet.com/forums/...d-about-absolutely-nothing-2.html#post1059794
BTW, I've gotten pretty proficient with the FEL, but there remain some areas with really HARD packed dirt that has to come down some more (FEL & back blade won't cut it, already tried), plus clumps of dirt from the hoe used to clear the drainage ditch along the front of the property (some 750+ feet long), & the drainage ditch through the property that needs maintainance.
Well, we'll see what the JD dealer says next week (we're expecting snow here), & I'll report back.
Thanx all!
DB
Well after much contemplation, reading, etc. have decided to go with 66" box blade. The rear width outside to outside of tires is just about 60". Dealer is delivering this afternoon. Great day for this, we had first snow, about an inch or so here in middle Tennessee so wont't get to try it out though. Hope I made the right decision!!
   / Box Blade Question #33
wushaw said:
Yes or some like myself use a drag of some homemade application to level/smooth an area but if it is for road use then a blade can be used for that application.
I myself use my FEL and box blade for my road fixin or making.
IMHO, I just think a BB might have more uses than a straight blade. Going backwards...it is straight..
   / Box Blade Question #34
I'm right there with ya Rob, I got rid of my rear blade just because I found the BB to be way more usefull...I won't keep something around If I can't or don't like the way it works...I already have two ex-wives..:) but I'm not buying another rear blade, I may try another wife though.lol
Thanks guys. 66" BB should be delivered in a couple of hrs. Wushaw:Good one about the wives::D
   / Box Blade Question #36
Just back for the JD dealer, with sticker shock. The Frontier BB2065 (5'5" wide HD) lists for $1043! :eek: We agreed that's too much & he's going to see what he can find in the same size & $7-800 range for me.
Any suggestions on other dealers I should check, remembering that I'm in NJ (not interested in a good deal that goes bad with shipping cost).
   / Box Blade Question #37
Here is a link to A&B Eagleline. They make nice stuff. I bought a super heavy box blade but they make lighter stuff too. Great people to deal with. They will hook you up with their nearest dealer to where you are. A & B EAGLE LINE EQUIPMENT The Shield of Quality
   / Box Blade Question #38
ExpediteMike said:
Thanks "Partsman". First use will be grading gravel on new driveway after the dump truck spreads it as he unloads it.
Last summer I regraded my drive (300 yds long) with a new bb on my 26hp new holland. It was my first summer with the tractor and my first project with the boxblade. First step was getting 7 dumptrucks of 5/8" crushed with fines dumped along the drive, spread out by using chains on the dumper and some driving skill by the dump truck operator. However it was very uneven before I used the blade, and it took quite some practice to get it looking good. In fact I recall my wife coming down and "talking loudly" at me that it was a mess, after about two passes. I kept at it, going up one side and back down the other (with the bb on a very slight tilt to put a crown on the road). After about 5 or 6 passes it was fantastic. Even the contractor who built my place was very impressed. It can be done; just be patient and play with the 3ph height and your driving speed. All in all it's pretty relaxing, as far as "work" goes.
   / Box Blade Question #39
Hi BrianCD. How did the dumper spread out the 5/8 with chains. I am interested on how he did it. I have 600 yards of road.
Also on your BB is your tilt manual or hydraulic to make that crown?
   / Box Blade Question #40
Probably used the chains to control how far the end gate on the dump truck opened. Thats how they did it at my old place.
ron
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
204158 (A57193)
204158 (A57193)
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
