Box Scraper Box Blade Question???
/ Box Blade Question??? #1
TEAM_ORANGE
Marlin, Texas
Kubota M8540HDC
I'm looking to purchase a new 8' box blade and I have a question. Is it worth the additional $250 to purchase the box blade with a hinged back, or should I save the extra $$$ and just purchase the one with the fixed back? What are the pros and cons?
/ Box Blade Question??? #2
I'd get the hinged one. It'll allow you to 'dribble' dirt/gravel at a rate determined by how open the tailgate is.
-J.
/ Box Blade Question??? #3
You had better have a big *** tractor if you're talkin bout an 8' box blade. jm
/ Box Blade Question??? #4
Only a $250 difference on an 8' box? Is that a light duty box or a very light duty box?
The swinging rear blade allows the front blade to dig in with less restriction (in swing mode) with nose down) so it digs deeper, faster and easier. When bolted down, the rear blade can be used tilted nose up, to smooth the ground without any digging action from the front blade.
I looked at your profile. I hope you are looking at boxes like the Gannon Industrial series like the high backed landscapers or similar. Either with or without hydraulic scarifier bars. Considering the power of your tractor, the hard Texas clay etc, you had best be getting one that has a weight in the 1500-2000 pound range. If not, you will bend it up fast.
jb
jb
I've looked at everything from VERY heavy duty industrial units all the way to the KK stuff sold at the local Tractor Supply. The heavy duty/commercial box blades seem to be way more than I need....I'm just looking for something stout enough to maintain/grade my 1/4 mi. driveway without falling apart!
/ Box Blade Question??? #6
If you don't have rocks or roots that will catch the blade, you can get away with the cheap units. But, if you are going to do more aggressive ground engaging, you will damage the cheap ones before you notice anything.
Certainly, if you don't need the (much!) higher priced industrial units - don't get them.
If you are just pulling gravel around to smooth the driveway, the fixed blade will probably be fine.
jb
/ Box Blade Question??? #7
Woods works for me. Never been disappointed in their products.
/ Box Blade Question??? #8
When it comes to most implements, you get what you pay for. As was already said, if you are just moving loose stuff around, then you might get away with a less costly unit, but for a multi use implement, you will for sure need one 1000lbs or more. I have a 75hp tractor that weighs over 12k. I have an 81" Gannon that weighs in at 980lbs and it has worked good for me so far. In the right conditions it will stop my tractor cold. If you are doing more than your road maintenance, I would give that 8' box a 2nd thought or two. An 8 footer seems a bit big to me.
Good luck with whatever you decide to get.
/ Box Blade Question??? #9
Off topic, but how do you like the 12 speed tranny on the 8540? Got many hours on it yet? I've got a 48/48 on my 105S and like it light years better than the regular 4 speed stick on my M9000s.
I love it! I've found it much easier to keep the engine revs and MPH where I want it.
/ Box Blade Question??? #11
How does shift? I should go for a demo at the dealer, but I'd be interested in your opinions if you can compare the shifting to the earlier 9000s. They shifted great for a tractor. My 105 shifts more like a tank with a Czech gearbox.
I can't compare to the earlier 9000s, but I can tell you that the transmission was quite firm to shift when new. Now that i've got some hours on the Hobbs and things are broken-in, shifting has become more smooth and fluid.
/ Box Blade Question??? #14
Wow, sounds smooth as 10 grit toilet paper!
jb
Well, not quite that badly, just not as light as the 9000. The biggest trouble is getting it into third gear- the shiftgate is very stiff and sometimes won't go into third, especially when roading it. Dealer was quite surprised to hear that, especially after almost 500hrs on the meter. I expect them to take care of it when things slow down and I can lay it up for a while.
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
2022 Bobcat T66 R - Series Skid Steer (A61166)
2022 Bobcat T66 R...
Decorative Horse Light Post (A61569)
Decorative Horse...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
429650 (A61165)
429650 (A61165)
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
