Rear Blade Box blade or Rear Blade?
   / Box blade or Rear Blade? #11
How far will the BX2200 be able to hydraulicly raise and lower the box blade? I'm thinking that if I got a load of driveway stone dumped, could I back up to the pile, raise the box to grab some stone, lower the box, then drive off to dump it somewhere else??
   / Box blade or Rear Blade? #12
What about a rotary cutter to go in there and just blow away all the brush? (hope you cut those trees close to the ground) Or get in there with a gallon or RoundUp in the Spring and after all the brush is dead, rotary cut it real low, rake it and seed it? bw
   / Box blade or Rear Blade? #14
Yes, that can be done; takes a little practice and the right length adjustment on the top link, and it sure helps if you have a hydraulic top link so you can frequently change the adjustment. Remember that you're dragging the contents of that box, not picking up and carrying it.
   / Box blade or Rear Blade? #15
The boxblade has an open bottom. The BX can lift it plenty high to grab a load and spread it. More effective will be to use the loader to to distribute the gravel and then smooth and spread with the boxblade and then drag it with a flexible tine harrow. J
   / Box blade or Rear Blade? #16
Thanks to Bird and TresCrows for the answers on the boxblade!
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
16ft T/A Flatbed Trailer (A53424)
16ft T/A Flatbed...
2020 International MV607 16ft Morgan Dump Truck (A55852)
2020 International...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
