John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,620
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
Not it does not. The cutting edge of the Box Blade will be 3" to 4" lower, that is why there are two stirrup holes.
It is easier to try it than to type about it. Give it a go.
I understand that the cutting edge will be 3 or 4" lower. What I don't understand is WHY it needs to be lower (except in the special circumstances I described in my first post). If your boxblade engages the ground properly when on level ground, the geometry of that engagement with the ground does not change just because you tilted the ground (and the tractor along with it).
I guess it doesn't really matter. If you need your boxblade to go lower, use the lower holes. If you need to raise it higher, use the upper holes. A fairly basic concept.
