Box blade neck bent
   / Box blade neck bent #1
cdover73
Greensburg, Louisiana
2006 Mahindra 4530
Well, I did it! Pushing a stump up the other day and creased the neck of my Bush Hog SBX 720 box. The stump was only about 7" or 8" but must have had a **** of a root system. I can still use it to drag my driveway and the pin goes in straight, but it is definately bent. I guess I am going to have to heat it (burning the paint off /forums/images/graemlins/frown.gif ) and bend it back straight. Now I see what I could have done to begin with, other than not overpowering the box. BTW, I have a Mahindra 4530. Anyway, once heated and bent straight, I will weld a piece of 2" angle across the front of the neck riser for a kind of strong back.
Has anyone done this and, if so, how did you fix it?
   / Box blade neck bent #3
If you can dissemble the bent part and use a hydraulic press instead of heat the metal will be stronger for it. Maybe post a picture so we can get a better idea of where the damage actually is.
   / Box blade neck bent #4
   / Box blade neck bent #5
I'd be interested in seeing a pic too. Don't quite know what the "neck" is, so would like to learn.
I can't imagine a box blade bending from just pushing against a stump, even though it was 'immovable' because of the root. All the energy would be released by the tires slipping if pushed.
Now, I can imagine bending something if the stump was rammed into, rather than just pushed. Because then something has to give if one gets a run at it and hits the immovable object. Sometimes the object gives, but more often something breaks. /forums/images/graemlins/frown.gif
   / Box blade neck bent #6
   / Box blade neck bent #7
I bent the 1/2" X 4" support arms on my 5' KK. I was knocking down a forest fire near a friends house using reverse with my Branson 3510.
I took the bars off and used a 20 ton shop press to straighten. I would try to straighten yours cold. Heating softens the metal. Also I would not weld braces on to them. The next time something important might break like castings on the tractor.
   / Box blade neck bent #8
My 4530 is 4wd and is quite impressive for its pulling/pushing power, especially in reverse which I was in when this happened. I was in low range, 2nd gear, 4wd, and just above idle. Trust me, you don't have to hit something wide open to cause damage. I was backing into the stump at a crawl and got on the clutch as soon as I saw it didn't move, the tractor hardly ever grunted. I do agree about the heat. I don't want to do that, but I don't think I am going to be able to bend this cold! I may try using a hydraulic ram (port-a-power), but I'm afraid I won't get an even bend with it and could even cause more problems. I don't have any pictures yet, but here is a link to the box I have: http://www.bushhog.com/turftoc.html Just select SBX Box blades from the box blade pull down menu, I have the 720. The neck is what I refer to as the two wide plates that come up to form the top link of the 3pt. They are toed-in toward each other and the top link holes are not straight with each other any more, but the pin does go in. You can see where the paint has already chipped from being warped and that is the area where I will need to bend. I know I need to learn what the equipment will and won't take, but I am not impressed at how easy the box bent on this. I am always picky about how my equipment is taken care of, and I probably throttle back way more than I should. My fault for asking too much of the box, but I still don't think this should have happened to a 6' medium duty box.
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2011 Dodge Nitro SUV (A51694)
2011 Dodge Nitro...
2004 Land Rover Range Rover HSE SUV (A51694)
2004 Land Rover...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500 4x4...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
100 FUEL TANK (A53843)
