Box blade hitch ball.
   / Box blade hitch ball. #1
dunhamg
Waterville, IA
LX 279, 4120
Anyone else ever use their box blade to move goose neck trailers with? I mounted a 2 5/16" ball on the back of my Frontier 5 1/2" box blade by drilling out the existing center hole to 1" and mounting the ball there. Seems to work pretty well.
Any thoughts or suggestions?
Grady
   / Box blade hitch ball. #2
I welded a reciever on the back of mine. Saves me taking it off
   / Box blade hitch ball. #3
I never use my box blade but i do use my rear blade alot to move trailers sure make's it fast and easy.
   / Box blade hitch ball. #4
Here's mine.
Boone
   / Box blade hitch ball. #5
I welded a ball to the top of my LP quick hitch, has worked great for many years
   / Box blade hitch ball. #6
I also welded in a receiver...
   / Box blade hitch ball. #8
Just a thought... You said gooseneck trailer moving. Remember when moving a goose neck the point of attachment is above the center of the rear wheel. This is an invitation to disaster if the trailer is or was enough load to make the tractor rear up. A change in land elevation or a snag will change a docile trailer into something that forces the tractor to throw its front to the sky.
:eek:
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
2013 PETERBILT 367 DAYCAB (INOPERABLE) (A52472)
2013 PETERBILT 367...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
2006 BIG TEX 25+5 GOOSENECK TRAILER (A52472)
2006 BIG TEX 25+5...
